09-27-2011, 12:02 PM   #1
Spodeworld's Avatar
Manual lenses and light meters
Anyone who uses manual lenses knows that in-camera metering can be tricky and unreliable. I was wondering if a hand held light meter would be a reliable alternative to the in-camera exposure meter.
09-27-2011, 12:12 PM   #2
Reliable- pretty much. Convenient- nope, it takes forever compared to just pressing the green button. Usually a fixed EV shift is enough to correct any shortcomings in manual metering.
09-27-2011, 12:34 PM   #3
RioRico's Avatar
As Adam said. Chimping test-shots and adjusting exposure is fast and convenient. One possible exception would be in a situation where light and subject are consistent but you're moving to many different angles and distances, and you want the entire series equally exposed. Then, an incident (ambient) light meter can be useful, rather than taking reflected-light readings. But you can get the same effect by manually metering in-camera, chimping and adjusting till you get it right, then locking-in that exposure for the series.
09-27-2011, 06:14 PM   #4
mysticcowboy's Avatar
If you have an iPhone, iPod Touch or Android phone there are some inexpensive light meter apps that are easy to use.
09-28-2011, 09:43 AM   #5
Spodeworld's Avatar
Now that's an interesting idea....need to check it out.
QuoteOriginally posted by mysticcowboy Quote
09-28-2011, 05:45 PM   #6
DaveHolmes's Avatar
Using the Green button and knowing your lenses is probably a better way to go...
For example when my Pentax-M 40mm 2.8, when the Green button at tells me 1/180th then I shoot at 1/125th or 1/90th as I know it consistently under-exposes slightly on the K-x...
09-29-2011, 07:13 AM   #7
Spodeworld's Avatar
Do you find the over/underexposure consistent among manual lenses at the various f-stops?
09-29-2011, 08:35 AM   #8
jatrax's Avatar
I did some rough tests on this awhile back and determined that each lens is consistent at various apertures. But a different lens may act completely differently. That said a 1 to 1.5 ev adjustment will allow you to use Av mode on most Takumars and come fairly close. Set it , take a test shot and adjust, when you are happy just go with it. There is unfortunately some variation with different apertures as well. Some lenses will be dead on at one aperture and under-expose by 1 to 1.5 stops at the other end of the range.
The best advice, if you want to use Av mode is to know your lens. Otherwise use the green button (or a/v button on k-x) and meter for each shot.
09-29-2011, 12:33 PM   #9
QuoteOriginally posted by Spodeworld Quote
Cant speak for others,but do find a small varience lens to lens and f-stop to f-stop.
Overall exposure value of scene is a large factor also,goes up/down accordingly.
Dave and Jatrax covers it well,use green button/Tv shift for speed and EV comp
for same reason.In addition, using EV comp is kind of like a "note to self" in that it
allows me to remember where things are should things get crossed up on E-dial.
Generally, my "A" version manual's are real close in matrix, numbers Jatrax has
are very close to what I found with "K"s and "M"s using center weighted.
RioRico and his camera monkey make a great point,
does help to "chimp"around a bit to get to where you want to be.
09-29-2011, 01:02 PM   #10
ducdao's Avatar
Which one are you using? I tried Light Meter on my iPhone 4 and the results are deceiving. My K100D is contantly underexposed by 2-3stops when used with data provided by Light Meter.
Maybe I'm doing something wrong.
09-30-2011, 07:10 PM   #11
Lowell Goudge's Avatar
There is really no mystery. Using a uniformly lit wall shoot using green button to set exposure at each aperture detend. Measure greyscale value at the peak ofmthe histogram
This will give you the exposure error Ideal exposure is about 110-120 greyscale with each 40-45 greyscale being 1 stop over a +/- 3 stop range
The moral is know your gear
camera, in-camera, lenses, light, meter, pentax help, photography
SL vs SV clip-on light meters asaru Pentax Film SLR Discussion 24 06-22-2011 03:10 AM
Light meters..Do we need them ? Tommot1965 Photographic Technique 4 01-17-2011 08:52 AM
light meters slip Pentax Camera and Field Accessories 6 01-08-2011 09:13 PM
older manual light meters slip Pentax Camera and Field Accessories 2 01-06-2011 06:14 PM
Light meters Naturenut Troubleshooting and Beginner Help 6 03-11-2010 12:40 PM
All times are GMT -7. The time now is 03:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
