Originally posted by dicko3000 A couple of months ago I used a can of compressed air to try and remove ONE piece of dust from my sensor. Unfortunately the canister was nearly empty and liquid came out with the air and sprayed all over the sensor.
I read various articles and decided to use eclipse cleaning fluid and Type 2 Sensor Swabs. I bought a kit that had a blower in it as well.
Firstly I used the blower, that didn’t help and I succeeded in getting black flecks all over the viewfinder - which i have not been able to remove.
I then used the pads with the cleaner on the sensor. It removed most of the dirt and I was happy enough. However when shooting at f22 I noticed a lot of dust and tried cleaning again. Over that last couple of months I cleaned it a couple of more times. Most recently I got fed up and used the pads again to give it a good clean. I also decided to us pec pads with a modified type 2 swab - here is where I think I really went wrong. I cut one of the type 2 pads in half and wrapped a bit of pec pad over it. I then used this with eclipse to clean the sensor. Soon after I noticed two scratches on the sensor - I checked by wiping over them again to make sure they weren't smudges - definitely not.
after much hair pulling and test shots I confirmed these were definitely scratches.
I feel stupid for trying to do this myself - I should have just sent it to a shop to get professionally cleaned. I don’t think I ever got all of the original crud off from when I used the compressed air.
Of course I shouldn’t have cut my own wipe and I shouldn’t have kept attempting to clean it after the first attempt didn’t work.
My advice is not to try and clean your sensor yourself but practice good avoidance techniques instead.
I got another quote today from Ashai repair for £120 or thereabouts. Now I have to choose whether to spend £120 on a camera that is 2 years old. Or try and sell it as faulty and then put the money towards a new camera I can't afford
I was hoping to upgrade next year to a k-5 looks now I face buying a k-r or living without a camera until next year when I might be able to afford a k-5!
Hi
JeffJS and I have published here a number of sensor cleaning posts. Search for them and read them.
Unfortunately you have done everything wrong that can be done wrong. Firstly, never use canned air. You know now why. Secondly, and I have preached this many times, don't use rubber blowers. Yes you have read this correctly! To start off with they don't remove dirt but just merely redistribute it inside the mirror chamber and there is the ever present danger for deteriorating sticky rubber to come loose from inside the ball and this will be neatly blasted on to the sensor. You have learned this fact now as well. (Also some blowers have Talcum powder inside)
I am still not convinced that you have actually scratched the sensor with the ill fated cleaning method you describe above. Unless you have done something really really stupid which you are not telling us. You have bombarded your sensor with such a massive amount of sh-t that any normal cleaning will not remove it.
I would go about it this way:
Go to your chemist (supermarket) and buy some distilled water. At the chemist buy a bottle (10 or 20ml) Ethanol. Then buy a good quantity (15 or 20) sensor swabs.
Step 1) wet a swab well with distilled water but not so well that it drips. Wipe the swab over the sensor in one move from left to right (or right to left) with firm pressure but not heavy handed force. Discard swab. Repeat this step at least 6 or seven times, (possibly more) discarding the swap every time.
Step 2) Take dry swab and repeat the wiping action as described in step 1, discard and repeat until sensor is dry.
Step 3) Wet a fresh swab with a few drops of Ethanol and wipe over the sensor in the same way as in step 1. Repeat this at least 2 or three times. You'll be the judge. (The Ethanol is 98% pure, the rest 2% is water which cannot be removed from it.) Ethanol evaporates very quickly, sometimes quicker than you want to because then it has not enough time to dissolve what you want to remove. In fact the water content can work here for you. I have at occasions added a drop of distilled water to 20ml Ethanol (with a clean pipette) knowing that some of the crap on the sensor can only dissolve with water and other crap only with Ethanol and by applying this mix I can catch both.
Step 4) Take yet another fresh swap or two and wipe the sensor dry.
Done, if you follow this method I bet you will find your sensor will come back clean. If it still is not repeat all the steps until successful, this is why you need a good supply of swaps. Don't be tempted to re use any of the swabs. I just refuse to believe that you can scratch the sensor that easily because the surface is harder than you think and unless you have attacked it with something really sharp. Anyway give it a go you have nothing to lose but everything to gain. Tell us how it went.
And search for JeffJs' and my posts, you will learn a lot. Best of luck.
Greetings
