10-19-2011, 11:22 PM   #16
O can't see anything on my iPhone with retina display...
10-20-2011, 08:03 AM   #17
QuoteOriginally posted by altopiet Quote
+1
+1
Just do another wet clean, but make sure you keep the swab on the sensor the whole time till you are at the edge before lifting it.
I try to clean it this way,but don't work.Maybe I should use water+wipe?
10-20-2011, 11:35 AM   #18
sterretje's Avatar
Dear personal,
I don't see anything in the indicated areas. Enhancing the contrast using curves in the Gimp can indeed make something visible in the indicated areas. However applying a similar contrast enhancement to a normal image will result in a very unnatural looking image.
Personally I would not bother if I have to put this much effort in to get it visible. As it really seems to bother you, I would say, go out and take some shots of various subjects. Next see if those lines are visible in your normal images using normal contrast settings where you're images look good to you.
Just my thoughts and good luck.
10-20-2011, 12:15 PM   #19
Philoslothical's Avatar
QuoteOriginally posted by personal Quote
No. This is not a good idea. However, if you do go ahead with this, and ignore all the other advice in this thread, at least use distilled water. Anything else has impurities that will dry on the sensor, causing you more problems.
I don't mean to be mean about this, but you seem determined to break your camera. You've been told by multiple people that these extremely faint marks have no impact on your photography, yet you seem to be obsessing about it. Well, everyone has dust and other crap on their sensor, most a lot worse than what you're currently experiencing. It's a fact of life with DSLRs. You will never be able to keep the thing completely clean all the time, so why fuss over it?
In all likelihood, you will make the problem worse rather than better if you continue to mess with it.
10-20-2011, 02:33 PM   #20
Ex Finn.'s Avatar
QuoteOriginally posted by Philoslothical Quote
+1.
Leave it be.
10-20-2011, 05:28 PM   #21
Got it.
Did I just scratch my VF screen? slr_neophyte Troubleshooting and Beginner Help 7 06-08-2011 08:02 PM
What causes flim to scratch with straight line (x2) hinman Pentax Film SLR Discussion 10 09-17-2010 07:48 PM
Can photography be learned from scratch? future_retro Photographic Technique 52 08-08-2010 10:47 AM
price reduction due to lens scratch? kpp80202 Pentax SLR Lens Discussion 6 12-15-2009 02:00 PM
Red Scratch marks? BlueEyes Troubleshooting and Beginner Help 3 11-29-2009 06:33 PM
All times are GMT -7. The time now is 04:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
