10-14-2011, 07:54 AM   #1
Syb's Avatar
K-7 and setting ISO range
Hi,
I have been struggling some time now because I want to set my K-7 to ISO100. Don't ask me why. Struggled so long that I forgot.
But how do I do that?
Neither the menu, nor the custom settings allow me to do so.
Help!
Thanks, Syb
10-14-2011, 07:55 AM - 1 Like   #2
First you have to enable the expanded iso range custom function, and then make sure shadow/highlight correction is off (expanded dynamic range).
10-14-2011, 08:03 AM   #3
Syb
Syb's Avatar
Wow Adam, good to see you're still here. And perfect advice. Thanks a lot!
10-16-2011, 04:49 PM   #4
Adam, is "expanded iso range custom function" referring to the same thing as "Expanded Sensitivity" in the menu? If so, then it's not true that it has to be enabled in order to get ISO 100. I just checked on my K-7; as long as the D-range settings are off, I can set 100.
10-17-2011, 06:23 PM   #5
Ex Finn.'s Avatar
QuoteOriginally posted by pentup Quote
Yup, he messed up. You are correct.
k-7, pentax help
Does setting the ISO/sensitivity range work in Movie Mode? BrianStanding Video and Pentax HDSLRs 8 03-13-2012 09:19 AM
D-Range Setting , K-5 ? dh4412 Troubleshooting and Beginner Help 11 10-14-2011 03:43 PM
Kx ISO extended range Yehoyaqim Troubleshooting and Beginner Help 4 04-26-2011 03:52 AM
Is it time for the ISO range to retire? bymy141 Photographic Technique 18 10-27-2010 10:17 AM
K-x extended ISO range alphalt Pentax DSLR Discussion 9 05-03-2010 10:30 AM
All times are GMT -7. The time now is 07:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
