Originally posted by ChrisJ It's very important that you format the card after you have downloaded the images in the camera that it's going to be used in. The problem is the DCIM (Digital Camera Image Management) file is different for every camera, the data stored in this file is a memory map of the card and tells the camera where in memory each image begins and ends, without the correct data and format in this file any images on the card will be invisible to the camera. The DCIM file for the Kx and Kr are different.
Formatting writes a new DCIM file, just deleting the images doesn't.
Format the card in the camera your going to use it in.
Take your pics
Download your pics to a hard drive (preferably two)
Used this way a card will never corrupt.
If you take a card out of your Kx to use in your Kr you need to format the card in the Kr, and vice versa.
Chris
If ever a citation were needed...
The DCIM directory is, as far as I know, completely ordinary. It is only a file in the strictest sense; to most people it would be simply called a folder. You can format a card on a computer (Windows, Linux, doesn't matter, but use fat32 for the file system), create a new folder called DCIM, stick the card in your camera, and it works, using the folder created from the computer. You can drop images stored on your computer, and taken by said camera into this new folder, and it will see them (provided you keep any subdirectories intact, such as the dated folders that normally hold the images themselves).
There is nothing magical about formatting a card in the camera, or especially in a specific camera. There is also no reason not to swap a card between cameras, with the caveat that the camera may not be able to display images taken with another camera.
There sure seem to be a lot of myths and superstitions surrounding SD cards, I don't get it.
