10-18-2011, 09:57 AM   #1
K200d auto bracket Q
Hi,
When I set my K200d to auto bracket drive mode, I was expecting to hear 3 photos to be shot, but the camera takes only one. Does anyone know what I am missing in order to be able to shoot the over and under exposed photos when auto bracket is selected?
BR/tohans
10-18-2011, 11:07 AM   #2
PRS
K200 d
You need to hold the shutter release down and keep it held down until you have taken all three shots - or press it three times. If you've been pressig once and then releasing as with most dslrs you will only take the first, unbracketed exposure.
10-18-2011, 11:12 AM   #3
ChipB's Avatar
According to the manual (pp 124-6) it should take 3 consecutive photos - if I remember correctly (I had a K200D) you have to hold the shutter button down for the entire 3 shot sequence. If you only take one photo, then the next 2 shots will be bracketed (assuming you take them fairly quickly).
If you don't have a manual, you can download one here: http://www.pentaximaging.com/files/product/k200dE.pdf
Good luck.
10-18-2011, 11:25 AM   #4
Thanks for the quick feedback both. I will try to follow your advise.
Kind regards,
tohans
auto, bracket, k200d, pentax help, photos
Odd Noise When Using Auto Bracket With K200D Tamia Pentax DSLR Discussion 0 04-02-2011 10:56 AM
Auto Bracket button on K20D? Reportage Troubleshooting and Beginner Help 3 11-09-2010 06:34 PM
k10d auto bracket oldstoat Pentax DSLR Discussion 3 04-21-2010 08:44 AM
K-x auto bracket slow fps? justDIY Pentax DSLR Discussion 4 03-18-2010 03:58 PM
K200D auto bracket AND IR remote? johngs Pentax DSLR Discussion 2 03-27-2009 09:36 PM
All times are GMT -7. The time now is 05:07 AM. | See also: NikonForums.com, part of our network of photo forums!
