Originally posted by jjhenders ...the pop-up flash and the shutter are not in synch. I'm thinking the flash goes off just slightly ahead of the shutter.
It's not impossible, but the chance of the flash and the shutter simply not in sync is pretty slim.
Please do these 2 tests:
1. Take a few photos with the camera and the built-in flash visible in a mirror. Post the photos with EXIF data. They will help with trouble shooting.
2. Turn on the built-in flash, set the camera in 2 second delay. Take a photo. You should see in this order:
- Hit the shutter release.
- The built-in flash fires the preflash strobe.
- Mirror goes up.
- 2 second delay.
- Shutters open - flash fires the main strobe - shutters close.
Write back as what you observe.
Originally posted by bjake At what shutter speed are you using the flash?I believe they only sinc up to 180.
If the shutter speed is above 1/180 sec, the flash will not fire in the first place.
