Originally posted by AlfredD
2. The apeture doesn't change at when changing the f-stop. I also wouldn't expect it to, am I correct?
That's correct. The aperture should remain at the largest, regardless of the aperture setting on the camera body.
Does the viewfinder appear dimmer than what it should be? (I know, it's difficult to tell if you have no other camera body to compare to. But the viewfinder should be bright enough for you to focus manually).
Set the camera to manual, with the smallest aperture (e.g. f/22), and a low shutter speed (e.g. 1/4 sec). Look into the lens and hit the shutter release. Do you see the aperture blades moving?
