If I was looking at moving over to the Pentax system which would be the best camera to go for currently? (K-5, K-7 K20-D).
I currently have a Canon 5D classic and I have quite a lot of older M42 lenses and Pentax gear coming my way and it would either make my canon equipment redundant or end up not getting used. Which camera would compare to the quality I get from my 5D.
I believe the M42 lenses would work better with a pentax rather than using an adapter on my 5D as there are mirror clearance issues with the FF Canon. I am also finding I am tending to just use my 50mm f/1.8 prime on the 5D rather than the other zooms I have essentially making them a bit redundant.
I would also gain image stabilisation and pop up flash from moving over.
I did learn photography on an Ashai Pentax SV from the 1960's with a 55mm Super Takumar lens which I still have.
If i did get a Pentax DSLR I would sell my canon stuff on.
All advice would be greatly appreciated.
