10-28-2011, 02:06 PM   #1
k-7 remote advice
I'm looking to buy a remote for my K-7. issue is between IR and wired.
range isn't a problem at all… the only reason I want one is so that I don't have to touch my camera when doing bulb exposures. i just need to be able to conveniently click a button in my hand and have the shutter open then click again to close or something.
10-28-2011, 02:59 PM   #2
The remote F is definitely the way to go. It can be used for family portraits as well. And, it doesn't just dangle there off of the camera.
10-28-2011, 03:04 PM   #3
seems similar to the remote wp—are there any disadvantages in the WP? cause if they're the same except for extra buttons and weatherproof i'll probably go for the WP one.
however i'm also concerned about angle… will i have to hold it at a certain angle for it to work?
10-28-2011, 03:16 PM   #4
Aegon's Avatar
WP has extra buttons, but they don't cause the K-5 to do anything extra. But it is waterproof.
I bought a $3 remote on that auction site. Works fine. If it gets wet, I'll buy another.
10-28-2011, 04:26 PM   #5
Ex Finn.'s Avatar
I would get the WP just for lightning shots in the rain.
10-28-2011, 05:00 PM   #6
I don't have my K-7 here to check, but as I remember, some features of the K-7 are disabled in IR remote mode (probably something related to wireless flash).
You should check it: set the K-7 in IR remote mode, and turn on the menu for flash, you'll see some icons are grayed out. If those features are important to you, get something like a Yongnuo set that can do RF. The K-7 treats the Yongnuo receiver as a wired shutter release.
Other than that, get 2 or 3 copied of the cheapo one from FleaBay or DealExtreme.com.
The Pentax F IR remote control used to have an advantage: it can be stored in the K10D/K20D vertical grip. But that doesn't apply to the K-5/K-7.
10-28-2011, 06:54 PM   #7
QuoteOriginally posted by Ex Finn. Quote
very good point, but i didn't think this was doable originally >.> will my k-7 and a WP lens be good in solid rain?
cause if so then that's great and pentax++
10-29-2011, 04:32 PM   #8
Ex Finn.'s Avatar
QuoteOriginally posted by capote Quote
I have not used any WR lenses in heavy rain. Just DA* and they are fine.
10-30-2011, 12:30 AM   #9
One thing you should know about the the weatherproof one -- you can never change the battery. The thing is permanently glued shut, so when it dies that's it. If non-weatherproof is ok, I got an off-brand generic one from Amazon for under $10. Works great.
10-30-2011, 02:30 AM   #10
SaikouShadou's Avatar
I've got the CS-205 (Cable Switch). I don't mind the length of it but you can't really get far compared a wireless one. but for bulb mode it's fine for me.
Only thing I found out is that it acts more of wired shutter remote if compared to the wireless rather then a remote. C3.16 & C3.17 only applies to IR remote, that's what i found out with my CS-205 doesn't bother me though cause my N900 nokia has IR remote function for my K-7
camera, click, k-7, pentax help, photography
For Sale - Sold: Pentax Remote F IR remote (CONUS) Ed n Georgia Sold Items 2 03-28-2011 03:01 PM
IR remote advice please adwb Troubleshooting and Beginner Help 18 02-07-2011 04:32 PM
K-R remote advice please adwb Pentax K-r 8 02-01-2011 07:02 AM
advice on reliable use of IR remote? amoringello Pentax Camera and Field Accessories 3 12-15-2010 04:57 PM
Remote shutter advice please rotorhead Pentax Camera and Field Accessories 1 12-15-2010 01:10 PM
All times are GMT -7. The time now is 11:07 AM. | See also: NikonForums.com, part of our network of photo forums!
