Originally posted by newarts
Your conclusions are pretty much correct except that a computer monitor and sensor have different aspect ratios. Your calculated numbers will be more consistent when you take the proper aspect ratios into account. Typical display pixel size is around 0.25mm, 0.01".
Displaying at 100% crop maps each sensor pixel to a corresponding display pixel so in a sense is the maximum practical image enlargement.
CoC plays an important role in identifying the f-stop beyond which diffraction softening is observable.
Diffraction effects become visible in a display when the diameter of the Airy Disk is greater than a display pixel.
Diameter.Airy.Disk = 2.44 (f-number) (wavelength)
For green light and a displayed image this becomes:
f-stop.diffraction = 3/4 [Display.pixel.width.micrometers (sensor.width/display.width)]
For example, with a display pixel of 0 .25mm and a display width of 10", diffraction will begin to show at an f-stop of:
f-stop.diffraction = 3/4 [250 (1"/10")] ~ f:18
If this image were enlarged by a factor of two (displayed at 20" on a 0.25mm pitch display), diffraction softening would become visible at about f:9.
