Originally posted by Damian.T
I had a brief conversation with a photographer the other who said that he always sets his camera to under expose as a matter of course, unfortunately I didn't get the opportunity to ask why.
So why would he do this and why?
And... I have a K20, how would I do it??
Ta...
I thought for a moment I spoke to you, I am in an area near Bolton Hill and I prescribe to the theory that Blown/Burned Highlights are unforgivable... but I see you're from the UK and not Baltimore
I am "Left of Center" both in personal tastes and photographs. I try to keep my peaks to the left of center when viewing a histogram. I think the advice is good, but you need to find out from PP what you consider "under exposed"... I usually do not under expose more than 1/3 - 1/2 stop and/or the peak of the histogram is not hugging the left side. I will always try my best to save highlights by underexposing enough or just finding a different composition that works; and the only rule of thumb I follow, you cannot save them all...
However, when using high ISO's, I might do the opposite...
When using anything other that Manual mode on the K20D, using the +/- will work; when using Manual mode, make the shutter speed faster...
