10-31-2011, 10:08 AM   #1
Spodeworld's Avatar
Pop up as fill flash
I've heard that when using the pop up flash for fill flash, it is best to dial in some Flash Exposure Compensation. I think that is generally true, since I've noticed that full flash has a tendency to overexpose the subject. I've heard that -1.75 is a good value to start with. I am wondering if this agrees with the experience of the users here.
Thanks
10-31-2011, 10:41 AM   #2
imtheguy's Avatar
Depends on the range, ambient lighting and subject but for outdoor shots I usually crank it down -1.3 for critter shots between 3-5m.
10-31-2011, 10:55 AM   #3
I generally use -1 with my FA35, on my k-r, for my daughter, and I'm usually in pretty tight.
10-31-2011, 05:08 PM   #4
RioRico's Avatar
An easy+cheap trick to diffuse the fill light: slip a thin white cotton infant's sock over the flash.
11-01-2011, 04:42 AM   #5
Spodeworld's Avatar
Thanks for the feedback.
@Rio - When you diffuse the light, do you usually use and Flash Exposure compensation? (infant's sock...cute trick)
11-01-2011, 08:59 AM   #6
reeftool's Avatar
I usually dial it down a little. I will normally take a couple of test shots and change the the flash compensation as needed. It's going to vary a little according to distance. The light and conditions are going to be different every time so trying to set a fill flash rule for all situations won't work. As for a starting point? I start with whatever the camera was set at the last time. I usually shoot first, look at the shot and histogram, and say "Oh,crap".
11-01-2011, 12:37 PM   #7
RioRico's Avatar
QuoteOriginally posted by Spodeworld Quote
Depends on circumstance, distance, ambient light, etc. If the flash is the main light, I may dial it up a little. If fill, I may dial it down. Best bet is to shoot, chip, adjust.
11-01-2011, 06:01 PM   #8
Spodeworld's Avatar
"Shoot
-- Chimp
--- Adjust"
I think I'm going to turn that into a bumper sticker!
camera, flash, pentax help, photography, pop
Fill flash with K-7? Loren E Flashes, Lighting, and Studio 6 01-24-2011 01:08 AM
k5 pop-up flash hook (that holds the flash down) broken... Thesorus Troubleshooting and Beginner Help 4 01-06-2011 08:34 PM
Fill flash.... rouds39 Pentax DSLR Discussion 25 12-09-2010 08:30 AM
Fill flash when you want SS above 180 - help! ll_coffee_lP Flashes, Lighting, and Studio 25 06-03-2010 11:14 AM
K2000 - Pop up flash will not pop up. tkindred Pentax DSLR Discussion 6 08-17-2009 08:54 AM
All times are GMT -7. The time now is 04:37 PM. | See also: NikonForums.com, part of our network of photo forums!
