10-31-2011, 05:59 PM   #1
setting diopter
what is the best way to set the diopter so that manual focus is true to what one thinks is proper focus? doesn't seem to be coinciding with the green dot focus indicator.
10-31-2011, 06:20 PM   #2
baro-nite's Avatar
https://www.pentaxforums.com/forums/pentax-dslr-discussion/141342-diopter-adj...ml#post1476641
Note that the focus indicator (green hexagon) is based on the autofocus system and thus unrelated to what you see in the viewfinder.
10-31-2011, 06:57 PM   #3
Ole
Ole's Avatar
Set it so that the thin (auto focus) framing lines in the view finder appear as sharp as possible.
That ensures that you see the focusing screen "in focus".
11-01-2011, 09:07 AM   #4
reeftool's Avatar
I set it so the framing lines and also the info in the viewfinder is the sharpest. I wear trifocals.
11-01-2011, 09:21 AM   #5
Wheatfield's Avatar
QuoteOriginally posted by Ole Quote
To add to this, set your diopter with no lens on the camera,
11-01-2011, 10:05 AM   #6
thanks, set with no lens on camera, should camera be turned on ( a k-5 ) ? i guess i can try that, and to baro-nite, it is probably the red focus confirmation that i meant. i should probably turn that off. also, seems like i want to set the sliding diopter thing between two of it's stops for it to be really clear, which seems kind of a pain.
11-01-2011, 10:30 AM   #7
baro-nite's Avatar
Red indicator is not focus confirmation, it merely tells you which AF point is selected. So maybe that's your problem right there. The focus confirmation indicator is the green hexagon in the middle of the LCD display at the bottom of the viewfinder.
For adjusting diopter it shouldn't matter if you have the camera turned on or off. I prefer the lens-off method and find it more accurate to look at the matte texture rather than the grid lines.
11-01-2011, 07:22 PM   #8
well, the green dot does light up for focus confirmation , even in manual mode, with an smc lens, on my k-5, i don't rely on it though. and the matte screen idea with the lens off worked great, seems like i have the lines in focus now. thanks.
11-05-2011, 09:54 PM   #9
Found this thread earlier today and I reset the diopter on my k-x with the lens off as suggested rather than with an af lens mounted like I'd done before. I use a split screen so don't have the AF guides so I adjusted it 'til the pyramids had hard black lines around them. I've just got back from shooting a techno night using my old, old SMC 50mm 1:7 (mf) without flash and pretty much always on f2:ish and I'd say I've increased my hit rate by a good 20%. I've spent the last year setting myself the challenge of not letting the camera do anything for me (always set to 'm', not using the green button for metering but doing it by eye, and not using the focus-confirm green hexagon.) Yes, I'm a masochist but I figured that that method would give me a better understanding of how to make my camera and lens take the shot that's in my mind's-eye. I do now after a year use the GB and auto lenses and love them, but I don't regret having gone about things the way I have.
That said I still can't believe the difference setting the diopter has made, I felt tonight that my 30 odd year old lens and entry level body were an extension of my own eye and that I was starting to reach the end of the plateau in skills I've been on for months now. I really can't believe that I never particularly considered the lens closest to my eye when I'm shooting...
11-06-2011, 04:49 AM   #10
wildweasel, have you tried the magnifiying eyecup? not sure if it fits the kx, i think my favorite lens is the k35 f3.5, aside from the dfa 100wr, which both i use manually, i only get maybe a third of my shots in really good focus using manual focusing, setting the diopter has helped though, the slrs had larger viewfinders maybe ? making it easier to focus with them than dslrs? wish they would concentrate on making good , large viewfinders for dslrs.
11-14-2011, 10:28 AM   #11
Not heard of those magnifying eyecups before, but one's on my to-buy list now. I looked them up and they do fit the kx and seem to have positive reviews. SLRs definitely had larger and brighter viewfinders; I've never really shot on film but I know some guys who do and there is quite a difference when I peer through the VFs on their cameras. Thanks for the suggestion, I'll let you know how it goes when I get one.
camera, diopter, focus, pentax help, photography
Where to find 67 diopter? Mike Pentax Medium Format 12 02-12-2014 08:28 AM
Diopter Setting Question prajno Troubleshooting and Beginner Help 19 02-14-2013 05:39 PM
Diopter adjustment -Mous- Pentax DSLR Discussion 11 04-26-2011 03:47 AM
Diopter for SLR GerryL Film SLRs and Compact Film Cameras 2 03-21-2011 05:02 PM
Diopter setting & Focus BillM Pentax SLR Lens Discussion 1 02-06-2010 04:00 PM
All times are GMT -7. The time now is 02:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
