11-04-2011, 04:56 PM   #1
AutoFocus K-7
Hi all. How do i disable AF on my K-7? I have read through the operating manual but; A- have'nt found how to do this yet, or B-don't understand the instructions.
Thanks guys.
Brian 101.
11-04-2011, 05:03 PM   #2
Should be like the K-5: front of the camera, on the lower-left (from behind) side of the mirror box (by the lens mount) - there should be a rotating lever with at least "A" and "M" positions. The M position mechanically retracts the autofocus linkage (so the lens can turn freely) and tells the camera not to focus.
11-04-2011, 05:18 PM   #3
baro-nite's Avatar
Also, if the issue is that you don't want autofocus to engage when you press the shutter release button halfway, you should be able to disable that specifically in the customization menu (without needing to change the autofocus switch as TomB_tx describes). You might prefer this to still allow autofocus using the dedicated AF button. That's how I have my K10D set and I expect the K-7 allows this too.
11-04-2011, 06:27 PM   #4
Yes, both of those are exactly right for the K-7. Set the switch on the front to M to disable totally, and there are menu options to turn on/off the shutter half-press option. If you have the latest firmware, there is at least one other option to do with the AF button on the back -- I forget what it is.
camera, k-7, pentax help, photography
Is the Autofocus up to speed on the K-5 or K-7? GLXLR Pentax K-5 30 06-03-2011 10:38 AM
k7 vs kx autofocus? boosted03gti Pentax DSLR Discussion 5 02-06-2011 01:21 PM
I was just wondering -- Autofocus noise redeleon Pentax DSLR Discussion 2 04-28-2010 06:50 AM
K7 - very awkward autofocus? pjd Troubleshooting and Beginner Help 2 01-01-2010 05:09 PM
Does this lens autofocus on K-7 and K-x pakuchn Troubleshooting and Beginner Help 20 12-20-2009 04:22 PM
All times are GMT -7. The time now is 05:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
