Originally posted by Kennod I can recreate the problem with a Lexar SDXC card as follows:
- take several shots (RAW+JPG) - only need 5 or 6
- if I import these, there is no problem
- now delete 2 or 3 of the images in camera
- now take 2 or 3 more shots
- now 1 or 2 of the images will be corrupted, either cannot be displayed in camera, or is corrupted when imported
- I have also had images that display in camera but but can't zoom in. These are corrupted when imported.
I have NEVER had any corruption after formatting the card, but ALWAYS after I delete some recent images and the take more.
I've used different programs to import, have used both K-5 and K-7 cameras and tested 2 versions of the same card. I put it down to something about this model of card and probably others. Hopefully it is something than can be addressed in firmware, but in the meantime I just never delete in-camera when using my Lexar 64GB SDXC card.
I just did the suggested test with 2 cards:
- Lexar Professional 128GB SDXC : I was able to reproduce the problem
- SanDisk Extreme Pro 32GB SDHC UHS-I 45MB/s : The problem did not happen
Possible conclusions:
- There is a problem with the K-5 handling SDXC cards
- There is a problem with the SDXC cards
- There is a problem with Lexar Professional cards
If somebody else has another brand of SDXC cards and do the test will be great, thanks
NOTE: Did the exact same test with JPEGs and the problem did not happen.
