11-08-2011, 12:16 PM   #1
Problem with my K200D
I have a K200D and when I try to use the 2 sec. timer it makes a clicking sound, and the picture comes out blurred. Up to 8-11 F stops it does ok in good light. In stops of 16-22 in low light it also makes this sound. It clicks a time or two, then the shutter works but the image is blurred even on a tripod.
Thanks for any help.
Melvin
11-08-2011, 01:31 PM   #2
Jonathan Mac's Avatar
Sounds very strange. Does it happen with the 12 second timer too? Is the click when it takes the picture, or when you press the shutter?
11-08-2011, 01:36 PM   #3
Maybe a silly question, but did you switch off SR when using a tripod?
11-08-2011, 01:45 PM   #4
Hearing multiple clicks is normal, because the camera is flipping up the mirror immediately and opening the shutter only after 2s. This is because the 2s delay feature is also a replacement for the mirror pre-release of the old days. The camera should have calmed down from vibrations caused by the mirror flipping prior to the opening of the shutter.
11-08-2011, 04:05 PM   #5
The clicks are prior to the shutter sound, and I did switch off SR. Always do when I use a tripod. Hearing these sounds are not normal. At least I never heard them before. They are so loud I can`t even hear the beep.
I guess I`ll just send it to Pentax.
Thanks for the replies
Melvin
11-09-2011, 02:44 AM   #6
The SR will be automatically deactivated when selecting the 2 or 12 second delay.
It sounds to me like there might be a problem with the mirror movement, though Im guessing as Ive never heard of a problem like this before.
11-09-2011, 04:45 AM   #7
Stone G.'s Avatar
I am a K200D owner too and use the 2s delay extensively due to the mirror lock-up feature. The fact that your pictures come out blurred indicate to me that there must be something wrong with the mirror lock-up mecahnism. It might also be an error in the Shake Reduction mechanism (that should turn off automatically when the 2s dealy is used). Under all circumstances it sounds to me as if a repair is required.
You might of course first try the usual "desperate" tricks and reset all settings; remove batteries; insert freshly charged batteries....
Please let us know the diagnosis once you have got it.
Good luck!
PS.: Just another very wild idea: Does it happen with all lenses that you have?
11-09-2011, 08:26 AM   #8
Thanks for all the replies. Yes, it does it with all lens. I think you are right when you say it has something to do with the mirror.
I shipped it off to Pentax this morning. Probably will hear the diagnosis next week. I will let you know.
Thanks again.
Melvin
k200d, light, pentax help, sound
Batteries problem with K200D cyberjunkie Pentax DSLR Discussion 28 06-08-2013 01:05 PM
K200D sensor shift problem Undefined (photo) Pentax DSLR Discussion 6 03-24-2011 03:05 AM
k200d Exposure and/or Sensor problem Hayward Troubleshooting and Beginner Help 8 03-10-2011 07:45 AM
Problem with remote connection on K200D PALADIN85020 Pentax DSLR Discussion 2 09-18-2010 01:12 PM
K200D Battery Problem David Tooker Pentax DSLR Discussion 10 11-15-2009 08:02 AM
All times are GMT -7. The time now is 01:17 AM. | See also: NikonForums.com, part of our network of photo forums!
