Originally posted by helhar Hi,
Question 2: Is it safe to use the K-R with a sync cable? I have a small Porta-Flash system and an old Ascorlight (Berkey?) 800 ws power pack and heads (my preferred system). I have no clue how to determine the voltage they put out.
Many thanks.
Heller
Checking the trigger voltage is easy. Just use a small digital multimeter. You can probably buy one at Radio Shack for $20, or anywhere else for $5. Set the voltage scale to 200 volts DC. Then, charge up the flash and measure the voltage across the synch terminals.
Studio lights often use 1/4 or 1/8 inch phone plugs to sync. If you don't have a cable that makes it easy to access the two wires, you can buy an appropriate plug (mono, not stereo), remove the plastic and just measure across the solder or screw terminals on the plug.
As others have said, around 5v is ideal, but anything up to about 20 volts is probably safe. The lower the better. Some flashes have trigger voltages of over 300 volts, which can fry the electronics in your camera. If your flash is that high, don't connect it directly to your camera. Wein makes several devices of various configurations, called "safe sync", that will insure that the camera is never subjected to more than 5v.
