11-16-2011, 04:45 AM   #1
Waj K Maj's Avatar
Samsung GX20
Hello all,
I need some sound advice, I have a Samsung GX20 with the standard kit lens (18-55), I am looking for a new lens, my problem is I don't actually know what lens are compatible with my DSLR. Aside from Samsung, I even emailed Sigma in London and they told me none of their lens are compatible with my camera yet online somewhere I found that there are some Sigmas that are.
So I am totally lost, after days of research I find lens but not sure which ones are compatible and which ones are not, is there just one site with a list that I can pick from? Or is it not as easy as that?
Another issue I would like some help on is that whats a prime lens and whats the difference between that and a zoom lens? With a budget of 500 I would like to buy two lens if possible, one with a zoom up to and around 200mm and another to replace my current 18-55 since I believe its not a good lens as far as kit lens come.
Thanks for reading people, I look forward to discussing and receiving some help!
11-16-2011, 05:11 AM - 1 Like   #2
All the lenses listed here will be compatible- there's a total of 37 new Sigma lenses in addition to dozens of Pentax lenses are available.
Pentax Reviews - Pentax Lens Reviews & Lens Database
Third-Party Lenses for Pentax - Pentax Lens Review Database
If you want a good walkaround lens I would look into either a Sigma 17-70 2.8-4 OS HSM, Tamron 17-50 f2.8 or Pentax 17-70mm F4. See the database for deets.
See also this in-depth review which does a cross-brand comparison so you can get a feel for what's out there.
DA* 16-50mm vs. Sigma and Tamron 17-50mm Comparison - Introduction
11-16-2011, 07:41 AM   #3
liukaitc's Avatar
maybe Tamron 17-50 f2.8 + pentax 55-300
not sure if that is within ur budget
or u can buy second hand here...always saw people selling these two lens here
11-16-2011, 06:23 PM   #4
DaveHolmes's Avatar
The GX20 is pretty much the same camera as the Pentax K20... It deffo shares the K-mount... As Adam says all lenses in the database will work...
11-16-2011, 10:11 PM - 1 Like   #5
sterretje's Avatar
QuoteOriginally posted by Waj K Maj Quote
A prime lens is a lens with a single focal length; so instead of the multiple focal lengths of e.g.18-55 it is e.g. 55 only. You have to zoom with your feet to get the subject larger or smaller.
The kit lens is a good lens. There are better lenses around, but you pay more
If you can stretch the budget a bit SRS has
Tamron SP 17-50mm F2.8 XR Di II LD Aspherical [IF] - Pentax Fit - Only 299.00 - SRS Microsystems 299
Pentax smc DA 55-300mm f4.0-5.8 ED Lens - Only 269.00 - SRS Microsystems 269
And they have some second hand stuff as well on Used Pentax Fit AF Lenses - Used Equipment - Page 1 - SRS Microsystems
London Camera Exchange might be another shop to look at.
11-17-2011, 09:32 AM   #6
Waj K Maj's Avatar
Thank you so much, now I have to spend weeks seeing which one but again choices are better than no choices at all, thank you.
QuoteOriginally posted by liukaitc Quote
I had a budget of 500 but since I have recently saved money on a flight, Iv got around 900 to spend, and Im always wary of second stuff, but again thank you.
QuoteOriginally posted by sterretje Quote
Thanks for that advice, but what I don't understand is why would you want a prime lens when you can just have a zoom lens? I mean surely there's more to the fact that its a set focal length?
And Thanks you all again (inc Dave)
11-17-2011, 11:55 AM   #7
sterretje's Avatar
Zoom lenses are compromises and therefor the image quality is not always optimal. They are also bigger and heavier; 2 or 3 DA Limiteds covering the range of e.g. a 17-70 are probably smaller and lighter (together). Zoom lenses are also not as fast; I think Olympus has/had a f/2 zoom lens, but I don't think you will ever find a f/1.7 or faster zoom.
11-17-2011, 03:42 PM   #8
DaveHolmes's Avatar
Yet... One has to assume that lens designers have at least 'toyed' with the idea but I imagine that the costs would be enormous!
03-22-2012, 03:21 AM   #9
Waj K Maj's Avatar
A bit of an old post but I settled for Sigma AF 24-70mm f/2.8 EX DG HSM, didn't go for a prime lens or a zoom lens that exceeded up to even a 100mm, I think I need more practice than to just throw away money, but I am pleased with this lens as it improves on the kit lens giving me enough scope to do what I like for now till I decided I need a longer zoom!
Thanks again people!
camera, gx20, help, kit, lens, pentax help, photography, samsung
Advice needed for: off camera flash guns for Samsung GX20 samsungx20 Pentax DSLR Discussion 8 07-11-2011 01:02 PM
Samsung GX20 Debug Mode Focus Adjust Webmonkie Pentax DSLR Discussion 5 05-26-2010 12:14 AM
Published using Samsung GX20 cabstar Pentax DSLR Discussion 3 02-21-2009 03:26 PM
WiFi for Samsung GX20 fwbigd Pentax News and Rumors 12 02-03-2008 11:02 AM
Samsung GX20 = Pentax K?D wheelgate Pentax DSLR Discussion 11 01-14-2008 02:47 PM
All times are GMT -7. The time now is 12:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
