11-22-2011, 04:00 AM   #1
Sigma mini-wide II 28mm f2.8 modified?
I saw this lens and it has "A position" for automatic aperture, I guess (the "A" seems to be erased). In Av mode the camera displays "F--" for aperture (and cannot be changed) but in exif data the aperture is "f2.8".
The mount of this lens seems to be different from another Sigma mini-wide mount (there are 2 pins missing).
On the rear cap of this lens is written: "for Pentax-K Ricoh XR-P" (I don't know if this caps is the orginial one)
My question is:
This lens is modified or is it ok? (serial number is 1135059)
Thank you!
PENTAX K-r  Photo
11-22-2011, 05:17 AM   #2
Lowell Goudge's Avatar
It seems to be modified or perhaps sold as a k mount not KA mount.
Are you sure the A position pin is missing? Check that this is not a pin that extends whe the lens is put into the A position.
You can also get a pin to put into that position I have used spring loaded IC pin array pins
11-22-2011, 07:00 AM   #3
I see in the picture that there is no hole for any pin on the mount. At others Sigma mini-wide II lens the I saw 2 pins on the mount. Maybe this lens it's only PK not PKA. Who knows!
07-31-2012, 07:28 PM   #4
may be modified to remove the ricoh pin in the bargain have removed all pins:
at least ur DSLR is safe i realised about ricoh pin when using mini wide it got stuck, took me a long long time to realise what happened once having removed the focusing screw started acting erractically, now it focuses now it does not- guess will have to realign the focusing screw (at the best).
BEWARE A LOT OF SIGMA MINI WIDES are sold as PK A when it is PK-R
08-01-2012, 01:04 PM   #5
Just1MoreDave's Avatar
This is a Sigma KA mount from an f2.8 lens which is about the same age. On this lens the Ricoh pin was removed; it's out of focus a bit, it was in the black spot in the bottom left.
You could probably get this Miniwide to work if you installed a spring-loaded pin in the A position, or modified the pin on your camera.
08-02-2012, 03:03 AM   #6
Ok, thanks!
aperture, lens, mini-wide, mini-wide ii 28mm, mount, pentax help, sigma, sigma mini-wide ii
For Sale - Sold: Sigma Mini-Wide 28mm f/2.8 buckyweet Sold Items 4 10-18-2011 04:53 AM
For Sale - Sold: Manual Lenses Sigma 28mm 2.8 mini wide, Sigma A 35-135mm 4-5.6, Sears 50mm 2.0 jqjones Sold Items 4 01-15-2011 09:02 PM
For Sale - Sold: Sigma Mini-Wide II 28mm f/2.8 $50 (CONUS) architorture Sold Items 6 09-14-2010 01:46 PM
For Sale - Sold: Sigma 28mm Mini-wide II f2.8 (US) meszidik Sold Items 2 03-17-2010 11:52 AM
For Sale - Sold: [Worldwide] Sigma mini-wide II 28mm f2.8 causey Sold Items 5 03-11-2010 07:40 AM
All times are GMT -7. The time now is 12:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
