Are there problems you ask?
Where have you been for the last 5 years?
Sorry for the sarcasm. But when I get a chance I will post a link to the issues. To be short about it, the K10d and K20D suffer badly from metering errors with manual lenses,
I have posted a plot that shows the errors, but breifly, at F1.4-2.0 you can expect it to under expose by about 1.5 stops, improving from F2 to F5.6 where it mets correctly to F11 whe it over exposes by about 2 stops, before setting back to 1 stop over by F32
here is the graph
what the graph shows is that the metering on all DSLRs has errors with manual lenses (the test sample is a K50/1.4, and that the *istD is the best at metering over the entire aperture range.
It can also be seen that the K10D metering can be largely corrected, by installing the *istD screen (type LL-60 I believe)
