11-27-2011, 02:07 PM   #1
Tamron 28-75mm and over exposure?
I just got my early "christmas present", the Tamron 28-75mm F2.8 lens. I have only taken under 100 photos with it but I already noticed some strange behaviour. I took some indoors pics and I got several that were significantly over exposed. For example, two shots taken only seconds apart in the same room (same lighting that is) using aperture priority had shutter speeds of 1/30 (correct exposure) and 1/13 (over exposed). My camera body is a K-x and I have not seen this happen with my other lenses (DA35, kit lens and tamron 70-300mm). Could this be a problem with the lens? With my camera body? With both, meaning this particular combination of lens and body?
11-27-2011, 02:26 PM   #2
RioRico's Avatar
Are the contacts clean? What metering mode is set? Is lighting contrasty, with patches of light and dark?
11-27-2011, 02:33 PM   #3
I can't check the contacts right now (not at home and don't have the camera with me). Have to check that when I get home.
Lighting was generally poor (had to bump up the ISO) but quite even. This happened even when taking two consecutive pics of the same subject. I used the default metering mode (multi metering, meaning the average of the whole pic area I guess).
11-27-2011, 02:38 PM   #4
crewl1's Avatar
Try using center weighted metering and see if it is more consistent.
With multi any change in any part of the scene can affect the overall balance.
11-27-2011, 02:51 PM   #5
Ash
Community Manager
Ash's Avatar
Any of the automated metering modes are very scene dependent.
Check the lighting of the whole scene and look into the mode that will best suit that particular scene.
11-27-2011, 03:04 PM   #6
bimjo's Avatar
QuoteOriginally posted by MadMan Quote
Did you change the zoom setting between shots? Metering mode and what you are actually metering can change drastically at different focal lengths.
11-27-2011, 03:33 PM   #7
Thanks for the tips!
Just out of curiosity, could this even be a problem with the lens? Or is metering problem always something that's camera body related? I'm not sure how the TTL-metering actually works in these modern DSLRs.
body, camera, lens, pentax help, tamron, tamron 28-75mm
Tamron 17-50mm, Tamron 28-75mm, Sigma 17-70mm, which lens for my trip to Greece? macky112 Pentax SLR Lens Discussion 15 11-20-2011 03:08 PM
Tamron 17-50mm f2.8 not as fast (bright) as Tamron 28-75mm f2.8 on Pentax K-x, PICS Edgar_in_Indy Pentax SLR Lens Discussion 38 01-10-2011 04:09 PM
lens comparison- fa50mm / tamron 17-50mm / tamron 28-75mm bimjo Pentax SLR Lens Discussion 11 03-16-2010 01:10 AM
Which is the better the Tamron 28-75mm or the Tamron 90mm macro? rustynail925 Pentax SLR Lens Discussion 17 02-01-2010 10:30 AM
K-7 vs Tamron 17-50mm and Tamron 28-75mm pkata Pentax DSLR Discussion 10 11-29-2009 03:26 PM
All times are GMT -7. The time now is 05:53 AM. | See also: NikonForums.com, part of our network of photo forums!
