Originally posted by Raindrops Hi guys. I'm new to photography and I have a Pentax K-X. I've been trying to figure everything out on my own and so far I'm getting nice photos, but they aren't vibrant. I want to avoid post-processing as much as possible as my aim is just to shoot and upload to Flickr. I know how to post-process to get the vibrancy, but I'd rather the vibrancy come from the settings on the camera.
This is the kind of thing I am aiming for... see the photo with the kids and umbrella
Please can you advise me on this... Thanks
Whatever setting you're currently using, try bumping up the Saturation and Contrast options, probably Sharpness as well
That might get you a more vibrant image, but "Landscape" or "Vibrant" mode should already have similar settings as default. You may also try to under expose just a 1/3 stop or so, this will help saturate colors but you might need to do some PP.
The "crisp" part will be all on the use of your current lens, you will need to stop it down a bit and then you got to take distance to subject in to play as well, and this is all assuming you have good even lighting.
Another trick is to try some fill flash as well, but this will take practice knowing how much to fill etc., etc., etc...
Bottom line, there is no setting you can use that will automatically produce clean crisp images with no PP but if you have a well exposed AND finely focused subject, you'll get pretty close. Practice...
