Originally posted by JinDesu Are you using AV mode or manual mode for your settings? Under AV mode, the camera forces the lens wide open no matter what setting you put the lens at.
Quite right. First, you've probably already set USING APERTURE RING to PERMITTED. This lets you use any AF or MF lens with an aperture set to something other than A. If you're shooting A-type or adapted lenses (like M42 screwmounts), you can preset the aperture and shoot in Av mode. But with an M- or K-type lens, which have only a mechanical aperture linkage, you need to put the camera in M mode and use the Green button for stop-down metering and exposure. In any auto mode, a K or M lens remains wide open, just as you describe.
