12-09-2011, 02:26 AM   #1
auto/manual focus problem
Evening all, i have a problem with my k200d after having used manual focus many times it now seems to be stuck on auto, can someone help please.
12-09-2011, 09:53 AM   #2
Nowhere Matt's Avatar
You mean you can move the focus switch from an auto focus setting to manual focus setting but the shutter will not release until the focus is locked? The menu tells you the camera is in an auto focus mode when in fact it is physically in manual focus?
We are just asking question to help narrow down the issue.
12-09-2011, 11:26 PM   #3
When I shift the af/mf button on the left hand side to mf ,so i can manually focus, the camera stays in auto focus.
12-09-2011, 11:47 PM   #4
jatrax's Avatar
Have you tried removing the lens? Possibly the screw drive is a little tight in the lens.
12-10-2011, 12:51 AM   #5
Yes tried that thankyou, I have had the camera for quite a few years often changing lenses, maybe the camera is getting tired .
12-10-2011, 07:51 AM   #6
bimjo's Avatar
Does it act the same if you switch the camera body to MF?
Have you cleaned the contacts? (lens and camera)
Does it act the same with other lenses?
Have you offended any voodoo practitioners lately?
12-10-2011, 02:00 PM   #7
Thanks for your reply, it does act the same with all lenses, have not cleaned the contacts will try that, I have switched the body to mf many times, camera remains on af.
focus, pentax help
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
DA 70 f2.4 auto focus problem syain Troubleshooting and Beginner Help 7 08-30-2011 09:20 AM
Problems auto focus assist in manual tonybolo Pentax SLR Lens Discussion 5 06-11-2011 06:20 PM
manual focus, auto aperture 55? Impartial Pentax SLR Lens Discussion 4 10-12-2010 05:36 PM
Sharper images--auto or manual focus Dimeman Photographic Technique 10 02-05-2010 11:01 AM
All times are GMT -7. The time now is 08:27 AM. | See also: NikonForums.com, part of our network of photo forums!
