12-09-2011, 08:49 PM   #1
LegOverHead's Avatar
Fast Moving Objects
Is there like a technique to shooting moving objects, my Tamron 28-75 cant focus that fast enough. Only solution I can really think of is manual focus.
12-09-2011, 09:00 PM - 1 Like   #2
Docrwm's Avatar
Pre-focus and trap-in-focus are going to help a lot.
12-09-2011, 09:11 PM - 1 Like   #3
RioRico's Avatar
To expand a bit: Trap-focus aka catch-in-focus (CIF) is very useful. Prefocus on a spot and hold down the shutter button. When a subject comes into focus there, the shutter snaps.
Another technique is zone-focus or hyperfocus. Set the focus and aperture for a desired DOF and hit the shutter when the subject is within that zone. I pace-off distances for this trick.
Yet another way is to set your autofocus to AF.C (continuous) and the drive mode to burst or continuous, and just spray-and-pray.
And of course, if the subject isn't too far away, a BIG HONKING FLASH may stop its motion visually. Good luck!
12-09-2011, 09:14 PM   #4
QuoteOriginally posted by Docrwm Quote
To expand a bit: Trap-focus aka catch-in-focus (CIF) is very useful. Prefocus on a spot and wait for the subject to move into focus there. Another technique is zone-focus or hyperfocus. Set the focus and aperture for a desired DOF and hit the shutter when the subject is within that zone. Yet another way is to set your autofocus to AF.C (continuous) and the drive mode to burst or continuous, and just spray-and-pray. If the subject isn't too far away, a BIG HONKING FLASH may stop its motion visually. Good luck!
Thanks guys, going to give this a shot!
12-09-2011, 09:31 PM - 1 Like   #5
Brooke Meyer
Guest
Track with AF Button
Follow the subject using the rear AF button. Stay on it and you'll be good when you press the shutter. This with a Tamron 28-75. I have lots more with the Tamron.
PENTAX K20D  Photo
12-09-2011, 09:33 PM   #6
Brooke Meyer
Guest
12-09-2011, 09:38 PM - 1 Like   #7
Frogfish's Avatar
You don't say what the object is but panning can also help especially if used in conjunction with AF.C.
12-09-2011, 11:15 PM   #8
QuoteOriginally posted by Brooke Meyer Quote
Not to sound dumb, but rear AF button? And excellent picture!
QuoteOriginally posted by Frogfish Quote
Like moving cars, moving people (especially breakdancers)
12-09-2011, 11:51 PM   #9
jatrax's Avatar
QuoteOriginally posted by LegOverHead Quote
You did not mention which camera you have but the AF button is a button on the back of some Pentax cameras. I know the k-x and k5 have it not sure about others. It needs configured in the menus depending on how you want it to work. It can be in addition to the AF function in the shutter release or instead of it.
12-10-2011, 12:06 AM   #10
Mike Cash's Avatar
After reading advice about using the rear AF button repeatedly over the last few years, I decided to give it a try at my recent dance shoot.
Frankly, I didn't see the point to it. All it did for me was give me an awkward grip in the camera.
12-10-2011, 01:07 AM   #11
RioRico's Avatar
QuoteOriginally posted by Mike Cash Quote
I use the rear AF button on my K20D very very rarely. For me, it's only to prefocus to bring the AF into the right range to avoid hunting at a critical moment. Yes, it makes for a very clumsy and awkward grip. I certainly wouldn't use it to track fast-moving objects.
12-10-2011, 09:13 AM   #12
Marc Sabatella's Avatar
I'm sure it's different on different models, but on the K200D, I can and do shoot with my thumb on the OK button (our equivalent of the AF button) all day long and I don't find it awkward at all. On the contrary, I find it essential, and wouldn't want to consider working without that option for moving targets. But FWIW, I have it set so the button temporarily cancels AF, rather than to enable it. So shutter does AF *unless* my thumb is on the button. I totally depend on this in my following of moving targets. Both for the ability to prefocus but also because with my thumb on the button, I can track focus manually. Beats having to actually constantly switch in and out of MF mode using the lever on the front of the camera. This assumes, of course, you are using a lens with Quick Shift.
12-10-2011, 11:21 AM   #13
Using the Pentax K100DS
12-11-2011, 12:44 AM   #14
Brooke Meyer
Guest
Takes a little practice
It might take a little getting used to. I've done it for so long, its second nature. This from today. Tamron again. too.
PENTAX K-5  Photo
12-11-2011, 01:42 PM   #15
If you are shooting cars, use continuous focus and panning, but don't stop panning right when you push the shutter release button, continue panning as the car passes by.
Here are a couple I shot.
Btw, Both are running around 200 mph.
PENTAX *ist DL  Photo
camera, focus, objects, pentax help, photography
So how do YOU handle focusing on moving objects? veezchick Troubleshooting and Beginner Help 19 12-20-2011 02:50 PM
How to calculate minimum shutter speed for moving objects? Alberts Troubleshooting and Beginner Help 12 11-14-2011 01:52 AM
Nature Moving Fast WiseOx Post Your Photos! 4 09-03-2010 06:42 AM
Fast moving dogs. Dekka Post Your Photos! 6 08-20-2008 02:20 AM
Tips on concert photography, low light, fast objects... praterkeith Photographic Technique 4 04-28-2008 02:47 PM
All times are GMT -7. The time now is 10:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
