12-12-2011, 02:00 AM   #1
k7 + Metz 44 AF-1 = no trailing curtain sync?
Hello.
I've been reading some threads on the forum but haven't found a satisfying answer to my question.
From what I've read pentax uses the p-ttl to manage the trailing curtain sync, instead of just letting the center pin fire at the end. (why?)
The thing is I can't get my newly bought Metz 44 AF-1 to make a trailing curtain shot with my K7. No matter what settings I use (camera set to M, Tv, Av, P and flash tested on both TTL and M) it always fire the flash directly after first curtain. I tried the flash on my small Panasonic LX3, and the trailing curtain function worked perfectly there with the flash in M-mode.
According to Metz manuall the flash should be able to do 2nd curtain (set up in camera).
Using 2sec delay trigger I can se the P-TTL pre-flash, so P-TTL should be working, right?
Unfortunately I dont have access to an original Pentax Flash, so I can't test if the problem resides within the camera or the flash unit. :/ (built in flash works fine with trailing curtain.)
Anny ideas?
12-12-2011, 07:49 AM   #2
You don't actually say - are you setting the flash to 2nd curtain synch in the camera?
12-12-2011, 08:08 AM   #3
Yes, I do. Tried both slow >> and only >>.
No difference.
Flash only triggers with first curtain.
12-12-2011, 01:07 PM   #4
Talked with the swedish general agent of metz today (importer Focus Nordic). They would look in to the issue to see if there is a compability issue or if the flash unit in fact is unable to preform trailing curtain shots with pentax models (even tho the manual sais so.)
Also spoke to Pentax an metz Main repair shop in sweden (Kameraservice Kungsör). The technician didnt have any metz 44 available for test shooting. But as he explained it trailing curtain with pentax original flashes is usually a setting made on the flash unit itself, not in the camera. (Haven't tried anny of the org. flashunits, so correct me if I missunderstood this.)
Will post again once Focus Nordic gets back to me.
12-13-2011, 04:49 AM   #5
Stone G.'s Avatar
As I understand the Pentax camera manual(s) you will need a flash unit where you can set trailing curtain option on the flash - which you cannot do with the Metz 44 AF-1 (I have that unit myself).
Thus the Metz manual's instructions (p. 98) to set REAR on the camera body and the pentax manuals instructions to set the function on the flash unit is a real Catch-22.
01-09-2012, 07:56 AM   #6
QuoteOriginally posted by pjaer Quote
Hi, I have the same problem with my Pentax K20D + Metz 50 AF-1. I set REAR mode in the flash unit and flash menu in the camera. I do some shots without metz, but with build in flash unit. This problem was actually again. I saw prefalsh again in a trailing curtain mode.
I think it is trouble in the pentax firmware. But it might be some pentax feature.
We have ask this question to pentax service.
01-09-2012, 12:12 PM   #7
Recived reply from Metz germany today:
Many thanks for your e-mail as of 02. Jan. 2012.
Basically the mentioned digital-camera Pentax K7 also is equipped with the synchronisation on the second curtain. However, if this function is switched on at the camera only the built-in flash unit of the camera works at the second curtain. The external flash unit isn't controlled by this setting. This depends on the camera.
In order to use the synchronisation on the second curtain the function has to be set at the external flash unit. Unfortunately the flash unit mecablitz 44 AF-1 digital for Pentax isn't equipped with this setting. Therefore this function can't be used by the combination of the mecablitz 44 AF-1 digital for Pentax together with the Pentax K7.
However, the afore-mentioned function can be used with the flash unit mecablitz 50 AF-1 digital and 58 AF-2 digital for Pentax. These flash units are equipped with the necessary setting.
We regret that we are unable to give you a more positive reply and remain
with best regards
i.A. Roland Laemmermann
Technical Support
So there it is, The Metz 44 AF-1 is NOT able to do a trailing (REAR) curtain shot with the pentax K-7.
01-15-2012, 08:43 AM   #8
mattdm's Avatar
Thanks for investigating this. I confirmed with my Metz 48 AF-1 and Pentax K-7 that the on-camera setting has no effect on the hotshoe flash, which supports the observation. I've updated my guide to reflect this!
af-1, camera, curtain, fire, flash, k7, metz, metz 44 af-1, p-ttl, pentax help
Leave on Trailing curtain sync? Kitty Photographic Technique 5 03-08-2011 07:54 AM
Why does my k20d flash twice when using trailing curtain sync? enderkasim Pentax DSLR Discussion 6 01-28-2010 05:37 AM
Trailing curtain sync problem? hoanpham Troubleshooting and Beginner Help 3 11-20-2009 05:18 PM
Sunpak 383 trailing curtain sync bentax Pentax Camera and Field Accessories 5 08-31-2008 11:29 PM
Does my K200D have rear/trailing curtain flash sync? K200D Pentax DSLR Discussion 2 07-29-2008 06:32 PM
All times are GMT -7. The time now is 09:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
