Originally posted by Antanico Hello again,
keep pressing half way the shooting button while you are trying to unlock/lock the AF/MF switch until you hear a possible click or unjammed reaction.
If it fails I am afraid you need a lab assistance.
Regards,
Ant
Hello,
I just want to give an update about this issue.
I noticed that this issue tend to happen when a DA Lens is mounted after the use of a Manual or A lens.
I discovered that the switch goes back to normal only if the AF lens is mounted after that the position MF is switched back BEFORE the removal of the Manual focus lens and setting the dial in AUTO.
Repace the lens and have a couple of shots in Auto.
The switch will work again.
Regards,
Ant
