12-16-2011, 08:57 PM   #1
K5: accidental deleting of SD card folders
I have a new k5.
I have noticed that the camera creates a new file folder for each day, which in itself seems like a good idea.
However, much to my annoyance, I have discovered today that deleting an earlier day's folder on the camera from the computer end (as seemed logical since I had earlier downloaded those photos) deletes all day folders and folder contents from the SD card, including as it happened a gem of a photo from today that I had not yet downloaded. Has anyone noticed this, and is there any possible way to retrieve the most recently deleted photos from the SD card (I haven't touched the card since this happened)??.
Would much appreciate any help.
Thanks
Andrew.
12-16-2011, 09:01 PM   #2
Docrwm's Avatar
I believe that Sandisk has an SD recovery program that could fix your problem. Might check for it here and on there website. Good luck.
12-16-2011, 09:05 PM   #3
Ole
Ole's Avatar
To be on the safe side I've made it a rule to never write to or delete anything on the SD card from the computer.
As Docrwm suggests, there is a good change that you can recover the deleted files.
12-16-2011, 10:09 PM   #4
I've deleted a previous day without deleting every day. ???
12-17-2011, 02:03 AM   #5
Philoslothical's Avatar
QuoteOriginally posted by Andrew Crouch Quote
Under normal circumstances that does not happen, period. Something is wrong with your card, reader, or perhaps user error of some sort. The only way you could accidentally delete all the dated folders is if you either highlighted more than one before deleting, or deleted the whole DCIM folder by mistake.
First stop I'd make is to pick up Recuva if you're on Windows. Which OS and version do you use? It should be easy to recover the photos on the card provided you haven't written anything else to the card since.
12-17-2011, 04:08 AM   #6
sterretje's Avatar
Important: do not use the card till you have recovered the images.
There are plenty of recovery tools; some already mentioned. I've managed to recover a card that was all of a sudden empty using photorec. Although it should not make a difference, it's often advised not to use the computer for anything but reading the card; delete and format on the camera. Format 'needs to be done' anyway on the camera to re-create the DCIM folder (although you should be able to recreate that folder from the computer as well in an additional step).
I would think that the behavior that you've experienced is strange; it should not wipe everything. Which cards are you using? SD, SDHC, SDXC? The camera's driver for SDXC is often blamed for lost images (there are one or more threads about this); the behavior that you have experienced might be related if you use SDXC cards.
I have not had any issues with my 8GB SDHC cards on my K5, but I also don't delete / format using a PC.
Good luck with the recovery.
12-17-2011, 04:32 AM   #7
QuoteOriginally posted by sterretje Quote
Nah, it's not needed for that. Putting a blank formatted card in my K-r, it creates the folders when you take your first shot. No biggie. Creating the folder from a PC also works of course, a folder is a folder. I often do this, and recreate the last dated folder, so that it knows where to continue the numbering from.
Good point, if he's using SDXC cards, he must update to the current firmware.
12-17-2011, 04:41 AM   #8
stevbike's Avatar
I will normally trans all files from a SD card to the computer regardless of the number images I have on it. It saved me the trouble of loosing pictures like what happened to you. I will back them up on to a external hard from there to make sure they are save. I did run into a problem with deleted images on an SD card and used a recovery program to save the deleted pictures that where on the card. That should work for you as well.
12-17-2011, 05:04 AM   #9
this is where I'm at
I have tried 4 different recovery programs (including the SanDisk one) using your collective suggestions, and although they all retrieve 40 or so earlier jpgs, the one I really wanted (the most recently taken) was not recovered by any of them. I actually saw the photo on playback, so it was clearly stored prior to the deletion.
I am using a new SanDisk SDHC 4GB card, and Windows 7 in the computer. I didn't format the card in the beginning, because I have not needed to in the past with other cameras, as the camera always (as in this case) created the DCIM folder automatically. the card has behaved perfectly well for a couple of weeks until this happened.
I've run out of ideas. I've still not used the camera since the mishap, but it seems that unless someone is aware of a cleverer than average recovery program, i will just have to write it off to experience. Thanks for your suggestions though.
Andrew
12-17-2011, 05:54 AM   #10
You can try this one, it's my fallback and has provided some good results as far back as the Windows 98 days.
However, if Recuva couldn't find it, even with the "deep scan" option, it sounds like it got deleted and overwritten before you became aware of losing it.
Is it possible that these folders were lost before you deleted the one that you think caused the issue?
If I were you, I'd go out and get a new card right away. Where did you buy the 4GB one? There are a LOT of counterfeit ones on the market, particularly branded as Sandisk. Some counterfeit cards have a much smaller capacity than they report, so "filling" the card actually overwrites data already on it. It's a good practice to only buy memory cards from reputable brick and mortar shops, although a handful of reputable online dealers should be safe too.
12-17-2011, 06:31 AM   #11
sterretje's Avatar
QuoteOriginally posted by Philoslothical Quote
Thanks for that correction; will test it one day.
12-17-2011, 07:04 AM   #12
Docrwm's Avatar
Sorry about the loss of photos. It's not necessarily the camera though, even Sandisk cards can fail or it could have been a glitch with W7.
12-17-2011, 07:13 AM   #13
normhead's Avatar
There can be unforeseen mess ups for sure. I few weeks ago, I shot a few pictures, reviewed them on the camera after I took them, checked the histograms to make sure I had reasonable exposures... then got home and couldn't find them... I have no idea what happened, but like you, 4 pictures that were good enough that I remembered to look for them were just gone. I'm shooting with a K20D so not exactly the same but... sometimes stuff happens.
12-19-2011, 06:33 PM   #14
I don't know if this will help, but I accidentally deleted a whole folder of shots (user error, not technical glitch) and successfully used "Pandora" recovery program. Worked great. Sounds like your card might be bad.
After that incident, I never store more than 1 days' shots on my card--I always download them to my computer and empty the card. If I shoot in the morning and plan to again in the afternoon, I still download the morning's session before shooting in the afternoon. Call me paranoid, but I'd rather be safe than sorry!
12-19-2011, 07:49 PM   #15
aleonx3's Avatar
That does not make sense to me. You said you delete the 'all day folders', do you mean all the folder created by the camera per day? Or do you delete the entire DCIM folder which contains all the sub-folders (per day)? I don't know if there is a way to delete a folder from the camera (be interested to know how). I don't usually delete any photos until the SD card is full or almost full and I usually use the PC to delete the files (never DCIM). Well regardless, always of course, I hope you can recover the files/photos.
camera, card, day, folder, folders, k5, pentax help, photos, sd
Deleting images from sd card Johnny5 Troubleshooting and Beginner Help 8 01-18-2012 10:23 AM
Folders created by the camera Farmer_Terry Troubleshooting and Beginner Help 6 05-26-2011 09:50 AM
People Accidental picture buckyweet Photo Critique 3 09-15-2010 08:51 AM
Deleting using 6700 card reader sabarrett Digital Processing, Software, and Printing 2 05-17-2008 05:01 PM
SD Card Folders HOGFan Pentax DSLR Discussion 4 01-03-2008 11:00 AM
All times are GMT -7. The time now is 06:40 PM. | See also: NikonForums.com, part of our network of photo forums!
