12-18-2011, 12:13 AM   #1
Pink Pictures
I have a Pentax istD. I took pictures of a sunset two months ago and after that the camera was ok. However last week I took a batch of pictures and white background is replaced by Pink.
Someone said it may have been the sunset shots - does anyone know and is it terminal?
12-18-2011, 04:08 AM   #2
Post an example of what you mean (including EXIF info).
It could be a sunset lighting situation (you should know if that is the case), or a mixed lighting situation. It could even be a filter on front of the lens (Skylight1A?). Most likely it's an adjustment / correction.
12-18-2011, 04:17 AM   #3
sunlight in the window is pink
example attached - sunlight in window is pink
12-18-2011, 06:24 AM - 1 Like   #4
VisualDarkness's Avatar
Wow, it looks like the camera is on some illegal substances there, I hope somebody can help you.
12-18-2011, 07:09 AM   #5
What do you have your White Balance and exposure set to?
It definately looks wrong!!!!
12-18-2011, 07:57 AM   #6
Philoslothical's Avatar
I suspect the condition is terminal, and that the patient doesn't have very long left. Very sorry for your loss.
Your sunset shots wouldn't do this, especially since shots of the sun tend to be short exposures (otherwise they'd be so blown out as to be useless). The danger of shooting the sun is to your eyes in the viewfinder, and even that isn't too big a deal at sunset, usually.
I would suggest you make the most of this. That effect you're getting has the potential to be a very artistic interpretation of reality. It's almost like a low-key infrared thing going on there, very cool. I'd also start saving/shopping for a new body.
12-26-2011, 03:03 AM   #7
who can make a suggestion on replacement for Pentax istD L?
I have a pair of Sigma K mount lens for it... 18-125 and 100-300
12-26-2011, 04:20 AM   #8
What's your budget? K-x, K-r, K-5, they're all good. So is the K-7 but it's not known for amazing high ISO performance. If weather sealing is important to you, then a K-5 or K-7, or even a used K20D would be good options.
12-26-2011, 04:24 AM   #9
I like to take pics of Car Racing and the babes at the races
Landscapes and usual family pics
I have been caught in rain before with camera
Would like to use the current lens that I have
12-26-2011, 04:40 AM   #10
It comes down to budget. If you can afford the K-5, go for it, it's currently the best and has weather sealing. Prices have dropped on it quite a bit lately, shop around a little.
You will be able to use your lenses on any Pentax DSLR, so no worries on that front.
12-26-2011, 04:43 AM   #11
sam-joseph's Avatar
Not quite sure what you mean by "babes at the races". You might have to post a few pics to illustrate your style of photography, so that we can make an accurate suggestion on the best possible replacement camera.
Regards
12-26-2011, 05:05 AM   #12
just the promotional girls
12-26-2011, 06:41 AM   #13
QuoteOriginally posted by sam-joseph Quote
Regards
Hahaha! Thanks for the laugh after a long day.
12-26-2011, 07:42 AM   #14
If you've been happy with your istD up until now, there's a whole flock of cameras available. Do you want new or is used OK? K100D Super, K10D, K200D, K20D are all available in the marketplace and usually at very reasonable prices. KX, KR, K7 and of course the wonderful K5 are all available in the new (or almost new) / used market although the first 3 will take some searching to buy new.
How much do you want to spend? Start at a couple of hundred and go up to just beyond eleven hundred for a flagship. Take your pick, your lenses will work.
pentax help, pictures, sunset
Nature Pink but with........... eaglem Post Your Photos! 2 02-06-2011 04:34 PM
Macro Pink flower miss_alexx Post Your Photos! 2 05-15-2010 10:17 AM
Nature A pink flower.. Sparkfot Post Your Photos! 7 04-25-2010 04:03 PM
People Pink Emotion SLRPhotography Post Your Photos! 11 04-20-2010 08:25 PM
Nature Pink Rose Marc Photo Critique 8 04-13-2010 03:29 PM
All times are GMT -7. The time now is 09:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
