12-21-2011, 03:09 PM   #1
dark pictures on program setting
I have a Kx and I just purchased a Tamron 18-200 mm 3.5 lens. When I take pictures in program mode especially in low light they come out dark. I switch to manual and they come out great. Is my Kx not adjusting correctly for this lens?
12-21-2011, 03:26 PM   #2
Senior Moderator
Parallax's Avatar
When using Program mode, is your ISO set to Auto? If so, is it possible that you are using a higher ISO in Manual than what you have auto ISO limited to in Program?
12-21-2011, 03:53 PM   #3
SpecialK's Avatar
QuoteOriginally posted by Parallax Quote
But he'd still get properly exposed, very blurry shots.
12-21-2011, 04:02 PM   #4
Senior Moderator
Parallax's Avatar
D'Oh!
12-21-2011, 07:19 PM   #5
Marc Sabatella's Avatar
You'll have to post sample images in order for anyone to be able to say what might be going on. But one guess is that you are including a lamp or other light in the picutre and the autoexposure is just trying to exposure for that. Solution would be to be sure to lock exposure while the lamps is not in the frame.
12-21-2011, 09:10 PM   #6
HEEGZ's Avatar
you can also try increasing the exposure compensation if you can't figure out what is causing the change. my k-7 tends to underexpose on program, av mode, etc. and i will sometimes just leave it on +1 or +0.5 EV just to get a histogram I am happy with. this varies with the type of lighting though.
12-21-2011, 09:32 PM   #7
Falke's Avatar
I bet the exposure compensation dial has been turned to the far end... Check that first and put it to the centre. to +/- 0 EV.
check pg 107 in the manual. this applies to other settings too, it probably just happens to be set to an extreme in Program mode.
12-22-2011, 08:18 AM   #8
Thanks everyone
Falke, you were right. somhow the exposure dial got changed. I corrected that and it fixed the problem. I want to thank everyone for thier quick responses.
12-22-2011, 02:20 PM   #9
Falke's Avatar
Good work Kevin. Remember to use that dial to your advantage
kx, lens, pentax help, pictures, program
dark pictures with my new K-20 CAFEDE Troubleshooting and Beginner Help 9 09-16-2011 04:54 PM
Dark Pictures Stibbok Pentax DSLR Discussion 5 04-04-2011 08:29 AM
Dark purple pictures from K-X luma Pentax DSLR Discussion 7 09-20-2010 03:07 PM
K7 wont take pictures in dark?? XeroX Pentax DSLR Discussion 14 08-03-2010 04:41 PM
k-x: setting the program line preference anthonyl Troubleshooting and Beginner Help 4 01-13-2010 01:58 PM
All times are GMT -7. The time now is 05:13 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
