12-22-2011, 12:29 PM   #1
Rode Videomic Pro - Right Channel only
Hi All,
I believe my camera (K7) has developed a fault but need my camera for some work in early January.... So no time to send for a repair! But before I do I'll provide a breakdown of the problem:
I have just bought the new Rode Videomic Pro which is a Mono Mic that has a stereo output. It records to the right channel fine, but not the left. Has anyone else experienced a problem such as this? I have tested the mic and both channels appear to be working.
I can (frustratingly) work with this for the next job I have but believe this to be a hardware fault with the unit - anyone else have a differing opinion?
Thanks for the help guys!
12-22-2011, 12:45 PM   #2
dosdan's Avatar
It sounds like the stereo ext. mic input socket in the K-7 has developed a fault. Is is worth getting it fixed? It will mildly interfere with watching through a TV/stereo (cheapest option would be a mono to stereo cable adapter) or you may have a TV when you can select which audio channel to use.
In PP in Sony Vegas Pro you can tell it which audio channel to use for the soundtrack and I presume you can do that in other video editing programs.
I've got a RØDEVM (first version without the sensitivity switch inside the battery case so it's too sensitive for loud situations) and a SVM. I've not used them on the K-5 yet (I use them on 3 miniDV cams). With the K-5, if the video was important, I'd probably do a separate soundtrack with a Zoom H4 SD card audio recorder (no camera noise) and visually/aurally sync it in PP afterwards.
Dan
12-22-2011, 12:51 PM   #3
Hey Dosdan,
Thanks for the speedy reply! I know, I know.... It's the left channel I meant to say not the right on closer inspection. Clear as a bell through the right channel mind you. It means removing the left channel in post which I can live with for one project :-( What id does mean though is that playback through say VLC or WMP has no audio because of the damaged left track.
Looks like a repair which is what I suspected and whilst it is under warranty it would be worth doing once the event is over. Thanks again!
camera, channel, fault, mic, pentax help, videomic
K7 with Rode Mic Gianni_Schicchi Video and Pentax HDSLRs 7 08-25-2011 01:37 AM
For Sale - Sold: PENTAX 67 w 45mm f4 -- rode hard and put away wet (Worldwide) JeffJS Sold Items 6 01-27-2011 06:49 PM
Landscape SB Channel at Noon dasuhu Post Your Photos! 5 01-20-2011 01:14 PM
First test K-7 with Rode Stereo VideoMic jogiba Video and Pentax HDSLRs 29 08-13-2010 05:20 AM
More rode shots same set up trumpyman Post Your Photos! 10 03-15-2009 03:47 PM
All times are GMT -7. The time now is 10:31 PM. | See also: NikonForums.com, part of our network of photo forums!
