12-25-2011, 04:21 AM   #1
Lens compatibility confirmation: Will my MZ-30 lenses work on K-x or K-r?
Hi all,
I am a new member here and this is my very first post.
I would like to know if my old MZ-30 lenses would fit on K-x or K-r which I'm planning to purchase. I have read The Pentax Camera Lens Compatibility Chart and Pentax K-Mount Lenses Explained: The differences between various Pentax lens series but am still a bit confused. I'm not sure if I've interpreted the tables correctly.
Based on the above documentations, MZ-30 has Crippled KAF mount and uses F series lens. Both k-x and k-r use Crippled KAF2 mount and fully supports the F series lens used on MZ-30. Please correct me if I am wrong.
The 2 lenses for my MZ-30 are:
  1. Sigma Aspherical 28-80mm 1:3.5-5.6, macro at 80mm (It has an aperture dial)
  2. Sigma 70-300mm 1:4-5.6, macro between 200-300mm (It has an aperture dial)
Thanks and Merry Christmas to you all!
12-25-2011, 04:34 AM   #2
If it works on your MZ-30, it'll work on your K-r. That's how it is will all Pentax lenses
12-25-2011, 05:08 AM   #3
Thanks Adam. Are the lenses going to be 100% compatible or are there any features that k-x or k-r body does not support?
12-25-2011, 06:24 AM   #4
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
All lenses made by Pentax and for Pentax will fit a K-x and K-r or any Pentax DSLR.
12-25-2011, 07:00 AM   #5
Marc Sabatella's Avatar
If the lens has AF, the camera will support AF with it. If the lens has auto aperture, the camera will support auto aperture with it. But the camera won't magically do AF or auto aperture with a lens that doesn't support it. Also, for those few lenses that support power zoom, many modern cameras don't support that.
Completely ,amual lenses - ones that don't support AF or auto aperture - can be used in Av mode on bodies with a non-crippled mount that support Av mode, but not any of on your cameras, since they have the crippled mount.
12-25-2011, 12:20 PM   #6
RioRico's Avatar
Assuming your lenses have an 'A' or 'A(P)' position on their aperture rings, just set the aperture to that position, and you can control aperture automatically or manually from the camera; you can also use matrix metering and pTTL flash with your new dSLR. If they have an 'A(P)' position they may also have the bothersome Ricoh Pin, which is easily dealt with. If they are AF lenses, the Ricoh-pin bug doesn't exist. Do they autofocus on your MZ-30? If so, no problem!
12-26-2011, 02:16 PM   #7
Yes they autofocus on MZ-30.
Thanks for all replies. I bought a K-x body. My both lenses seem to work fine!
aperture, camera, k-r, k-x, lens, lens compatibility, lenses, macro, mz-30, pentax, pentax help, photography, series
Compatibility of 67 lenses with K bodies keruili Pentax Medium Format 14 07-30-2010 10:22 AM
Error "Confirmation" button in marketplace doesn't work with mobile version of site. tendim Site Suggestions and Help 4 12-05-2009 01:13 PM
K20D: Focus Confirmation & SR with M42 lenses? Jim Royal Pentax DSLR Discussion 10 04-14-2009 10:21 AM
Focus confirmation on K10D with M lenses farfisa Pentax DSLR Discussion 4 12-03-2008 09:22 PM
Having trouble getting focus confirmation with my M42 lenses mudman Pentax SLR Lens Discussion 8 11-07-2007 10:05 PM
All times are GMT -7. The time now is 12:41 PM. | See also: NikonForums.com, part of our network of photo forums!
