Originally posted by amoringello There is certainly an overheat protection circuit. So if these were fired quickly enough, you probably did set that off.
How fast did you fire those shots?
The manual doesn't state any specifics that I recall, other than in regard to the modeling light where it states something about using it for too long.
Same would apply for normal shots, if in quick succession.
thanks for the reply
Probably 40-50 shots in 20 minutes. Then the flash became erratic. Switching on and off could get me one or two more shots, same as opening and closing battery door.
Most shots were at relatively high power, as I use bounce flash
As I said , turn camera on this morning, same batteries and everything is fine
Its funny that I had not noticed this before this year
