12-25-2011, 01:24 PM   #1
Ricoh XR Rikenon APO 1:4.5 300mm lens mount damage
Hello,
This is my first post on these forums and unfortunately it's due to a problem with one of my lenses.
I recently bought a working ME Super body along with a SMC Pentax-M 50mm F1.7, Vivitar 70-150mm f3.8 MC Macro focusing zoom (one touch version), Cosina 28mm f/2.8 MC and a Ricoh 300mm F4.5 XR APO Rikenon lens on eBay for £33 plus £10 postage. To make it even more of a bargain they came in an aluminium flightcase along with a selection of hoods and filters and also a squeeze-bulb remote shutter release.
At first the only problems I saw were that the lenses needed a good clean and that the battery cover was missing from the ME super. After closer inspection of the Ricoh 300mm however, I noticed that the lens had been dropped and damaged to such a degree that it no longer fits in the camera body - It goes in but isn't able to fully turn into place. I've included a link to photos of the lens below as it's much easier than trying to explain the damage.
Ricoh 300mm Damage - a set on Flickr
Does anyone know what's required to fix this? Also due to the rarity of the lens I take it finding spare parts is not an option?
Thanks and Happy Holidays.
Keir.
12-25-2011, 02:27 PM   #2
ChrisPlatt's Avatar
Perhaps you can use the mount portion from another model.
There are plenty of inexpensive used XR Rikenon lenses around.
There are several considerations when looking for a direct replacement.
The positions of the screws must be identical and the coupling lever slots must be no smaller.
Thickness must be identical or focus will be affected.
Chris
12-25-2011, 07:15 PM   #3
Otis Memorial Pentaxian
QuoteOriginally posted by ChrisPlatt Quote
I just compared the mount on the damaged lens to my XR Rikenon 50/2 and the screw holes are not the same, so I guess you can rule that one out!
12-25-2011, 07:46 PM   #4
Steinback's Avatar
That's a pretty serious dent. I would be tempted to try removing the mount from the lens body, then straighten it out with some pliers and smooth off the rough points and anything causing interference with a fine file and sandpaper on a small sanding block. You will have to wash all the metals filings off before you test fit the mount to a body, but with some trial and error you can probably get the mount to a point where it will work even if it isn't pretty.
300mm, 300mm lens, body, damage, lens, mc, pentax help, ricoh, ricoh xr rikenon
Ricoh XR Rikenon APO F4.5 300mm Zubati Kit Pentax SLR Lens Discussion 12 09-30-2010 03:13 AM
For Sale - Sold: Ricoh Rikenon XR 50mm f/1.7 lens - PK Nick Siebers Sold Items 9 07-14-2010 12:08 PM
For Sale - Sold: Ricoh Rikenon XR 135mm f2.8 K-mount Lens Rykoh Sold Items 4 01-17-2009 10:37 PM
Ricoh XR Rikenon lenses with K-mount imadethis Pentax SLR Lens Discussion 4 10-07-2007 12:53 PM
All times are GMT -7. The time now is 09:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
