Anyone know an easy way to test the battery charger for my K7? I've got a multi meter, but not sure what I should be checking for. One of my batteries died, I put it in the charger, and it seemed to work as it normally does. (charging light came on, then turned off) After "charging", I put the battery back in the camera, but K7 said it was still dead. I've not killed another battery yet to see if it's just the battery or not, but battery worked fine up to this point, and I got plenty of shots out of it, so I can't imagine it just kicked the bucket, but stranger things have happened. It is not an original Pentax battery, and not sure of the age of it either, as it came with a used grip that I purchased.
