12-30-2011, 05:07 PM   #1
M42-Pk mount broke and is stuck to Super Takumar 50mm
Title says it all and I can't get the mount off, any ideas how to get it off without breaking the lens?
EDIT:
Also the camera doesn't recognize the lens when I put it on
12-30-2011, 05:26 PM   #2
Steinback's Avatar
Often it helps to use a K mount rear cap as a wrench to get the adapter off.
Have you set your body to aperture ring-permitted in the custom menu? If not the shutter won't release with manual lenses.
What part of the adapter broke?
12-30-2011, 05:38 PM   #3
johnkmt's Avatar
springclip?
have you tried to loosen or remove the screw that holds the spingclip in place? that screw isn't supposed to poke through to the threads but, after a lot of use it can become a burr in the threads.
12-30-2011, 06:39 PM   #4
jatrax's Avatar
Are the threads crossed? Possible on the cheap knock-offs as the threads are cut a little loose. As noted above a k-mount rear cap can sometimes help. If all else fails, use a dremel tool to cut the adapter in two places and it will just fall off. Be careful not to cut into the lens threads.
Post a picture and you might get better advice but
QuoteOriginally posted by jnigo Quote
broke and is stuck
can mean a lot of things.
12-30-2011, 06:53 PM   #5
A possibility is that the adapter is installed to the lens backward. If this is the case, you need to depress a pin on the lens to rotate the adapter out. Let me me see if I can find a photo.
lens, mount, pentax help
Super-Multi-Coated Takumar (M42) vs. Pentax-M (K-mount) BogdanMF Pentax SLR Lens Discussion 14 12-17-2010 04:32 PM
For Sale - Sold: Super Takumar 50 with Case + M42 K Mount Adapter (US) El Bolson Sold Items 3 04-24-2010 10:31 AM
For Sale - Sold: [US] Super-Takumar 1:1.4/50 mm lens with M42 screw mount cdurfor Sold Items 7 02-26-2010 04:04 AM
For Sale - Sold: F/S: Pentax M42 screw mount Super Macro Takumar F/4 50mm Donkeypunch Sold Items 3 08-11-2008 12:47 PM
All times are GMT -7. The time now is 06:07 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
