12-31-2011, 01:37 PM   #1
Exif
When using Picasa, it seems that it strips all of my JPGs of their EXIF when I save them after editing. Is there anyway to get this EXIF data back after saving? Or am I essentially out of luck?
*EDIT* And while we're at it.. Any suggestions for a good, free photo editor that will tide me over until I can get my hands on Photoshop?
12-31-2011, 01:54 PM   #2
Bob from Aus's Avatar
Not sure if this will work. I have copied a thread I started asking members opinions about software. https://www.pentaxforums.com/forums/digital-processing-software-printing/1656...re-novice.html
two suggestions
1. backup your original untouched photos. I do mine before I clean my cards
2. if you use a program such as adobe lightroom, your originals are not changed and therefor not degraded. The changes only occur when the photos are exported. the lightroom program imitates the changes on your screen and stores the data for when you are ready to export. I found a small amount of the exif data was stripped when exported.
12-31-2011, 02:02 PM   #3
Great thanks! I'll be sure to do that. I usually backup all my photos but for some reason I didn't in this case. Oh well. I'll look through that list and see what I can find for some software. I'll definitely be wishing for CS5/LR in the future though.
12-31-2011, 02:11 PM   #4
paulh's Avatar
Picasa by default saves a copy of the original file after editing. Check your Picasa folder - there should be a sub-folder there called 'originals'.
12-31-2011, 02:46 PM   #5
Hmm.. I can't seem to find an "originals" folder anywhere in my Picasa folder.
12-31-2011, 02:55 PM   #6
hcc
hcc's Avatar
I believe that Photome (PhotoME - Exif, IPTC & ICC Metadata Editor) can copy EXIF data file from one file to another :eg from an original file to a process file. Photome is a freeware.
Hope that the comment may help.
12-31-2011, 02:58 PM   #7
paulh's Avatar
QuoteOriginally posted by jbuck92 Quote
sorry, my bad - check your photo folders for the 'originals' sub-folder. For example, in a folder called "Christmas shots 2011", you'll find the originals folder. (if you saved an edit) There should be one for each of your photo folders where you saved an edited file. Picasa even prompts you when saving, that a copy of the original was saved to disk.
12-31-2011, 03:02 PM   #8
jatrax's Avatar
Photoshop is total overkill for photography, IMHO. If you are a graphic artist or professional then great. For mere mortals who just want to edit and adjust photos then Photoshop Elements is more than enough if you want to stay with Adobe. And Lightroom is by far the best choice for photographers unless you need layers or something else that it does not do. I use Lightroom for 95% of my needs and then edit in GIMP or Elements if I need something specific.
For free editor try GIMP. Free, open source and more than most of us will ever need.
12-31-2011, 03:25 PM   #9
Those aren't there either.
12-31-2011, 03:31 PM   #10
boriscleto's Avatar
For those of us who use Macs, Aperture and Pixelmator are all you need.
12-31-2011, 03:33 PM   #11
bluestringer's Avatar
Faststone is a good free editor, as is Paint.Net, which has a bunch of plugins available.
12-31-2011, 03:59 PM   #12
paulh's Avatar
You may have changed the default settings in Picasa. If you did, then a copy of the original wouldn't be saved. Go into 'preferences' and check your settings. Here's a screenshot of my file manager (PCLinuxOS, but would look similar to Win or Mac). I've opened the 'Dec 3 28mm' folder, and inside you can see the originals sub-folder. At any rate, I also recommend Faststone for a good free editor.
12-31-2011, 04:04 PM   #13
For free, Picasa and GIMP are what I have used and recommend to my students. For photography usage I would recommend Lightroom over Photoshop any day. Photoshop can do some things that LR can't but I can live without those things. I suppose GIMP might do them for free, but I haven't thought to try that until now.
12-31-2011, 04:37 PM   #14
Thanks guys, I'll look into GIMP and Faststone for a new editor
01-03-2012, 11:37 AM   #15
CqCasting's Avatar
GIMP v Windows
Like the thread you have going here. I found on my lap top, that GIMP is Not compatible with Windows 7. Made that discovery after downloading "Windows 7 Upgrade Advisor"
camera, exif, pentax help, photography
saving exif with new file name pentaxian85 Troubleshooting and Beginner Help 7 06-01-2011 11:53 PM
Owner Name in Exif yusuf Pentax SLR Lens Discussion 3 04-29-2011 10:41 PM
SR Icon EXIF fb_penpho Pentax DSLR Discussion 10 08-25-2010 09:54 AM
Is EXIF important to you? NecroticSoldier Pentax DSLR Discussion 8 07-23-2010 09:08 AM
Macro EXIF itself Andres Post Your Photos! 2 07-12-2010 06:34 AM
All times are GMT -7. The time now is 10:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
