Originally posted by dominikkolendo just thought i'd add:
i printed a 4x3 foot print from a kx 12mp image.
i opened the RAW and exported it as a 4x3ft@300dpi file, then opened in gimp and edited some levels and sharpened a bit.
(this was about a 300 GIGABYTE file btw, so every filter took about 20 seconds to apply)
from anymore than 2 feet away it looks like it was taken with a giant sensor, if you get close you can see the degraded image quality, but, if you print at 4x3 you dont exactly need the image to look good with someones face pressed up to it.
I am sure you meant Megabytes. A 4x3 ft image at 300dpi is 14,400 x 10,800 pixels for a total of 156 MPixels times whatever bit depth you were using.
A 12 Mpixel image, if well focused, will give great 4x3 ft prints but the choice of the re-sampling algorithm will dramatically affect the final quality. Most image processing software usually offer bi-cubic convolution as the highest level of re-sampling quality which is fine maybe for a 2X enlargement. You can get far superior results using a RIP (Raster Image Processor) engine to do the re-sampling on the fly before printing; just provide the original image and specify the output print size. A RIP engine can be expensive but if you print at large sizes often, it is a very good option.Alternatively you can use a print shop with such a setup.
BTW it is not necessary to re sample the image at that high (300) dpi. Anything in the 150-200 range is more that enough, and for large prints that typically will be viewed from a greater distance you can go much lower with good results. It is best to use an integer multiplier of the printer's actual resolution. For Epson printers this will be 90 dpi or180dpi so the printer firmware does not have to deal with fractional values during dithering. A RIP engine will do that for you on the fly so there in no need to make a special sized file for the print.
