Originally posted by Philoslothical It's also possible that the failure is coincidental with acquiring the 35mm. It sounds like the pin for the screw drive isn't extending properly, so it's not mating with the connection on the lens. Why it would fail, I have no idea, but it sounds like a likely explanation of what is failing.
Of course it could be coincidental but if I were sending my camera into service I'd send the lens as well as it is the most likely culprit other than simple timing and coincidence. If it isn't the lens, no foul as you couldn't use it while the camera is in for repair. However, if it is the lens then sending it could get everything fixed in one trip and not sending it could set you up for a repeat of the damage to the camera.
