01-09-2012, 10:03 AM   #1
mblanc's Avatar
Does Shooting RAW+ instead of JPEG impact frames per second?
Hello,
I am just beginning to experiment with shooting RAW+ and postprocessing - but I wonder: if I am usin Continous Shooting, will this reduce the number of frames per second I can record? I am guessing yes, since I am writing more to the card every time the shutter fires? If this matters - I am using a k-x with a class 10 card. Thanks!
01-09-2012, 10:31 AM   #2
westmill's Avatar
QuoteOriginally posted by mblanc Quote
Hello,
No ! The frame rate stays the same, but the amount of pics it will take is reduced. for example,
If your camera will take 20 pics at hi speed in RAW
It will prob take 40 in jpg. This is govend by how good the buffer is in individual cameras.
01-09-2012, 11:43 AM   #3
BigDave's Avatar
Also, the speed of your memory card will make a difference. You pay a bit more for the hi speed cars, but when doing video and multi-shot work, it is necessary! But it only helps up to the point you load up your camera buffer!
Regards,
01-09-2012, 11:48 AM   #4
With a slower card it may affect the frame rate. It should be easily apparent with testing -- you can hear it slowing down.
01-09-2012, 02:39 PM   #5
Anvh's Avatar
Only when the buffer is full untill that you'll shoot at 4.7fps.
camera, card, frames, pentax help, photography
[K10D RAW+]Exposure difference between RAW and JPEG sterretje Pentax DSLR Discussion 9 04-13-2010 02:06 AM
Shooting JPEG, Converting to RAW? Tamia Digital Processing, Software, and Printing 9 02-14-2010 08:46 PM
JPEG, RAW, JPEG + RAW...huh? Raptorman Troubleshooting and Beginner Help 14 12-22-2009 11:49 AM
RAW + JPEG with JPEG on One Star quality laissezfaire Pentax DSLR Discussion 58 12-10-2008 02:42 PM
RAW and JPEG Shooting - Filenames change? Alvin Photographic Technique 2 07-04-2007 07:25 AM
All times are GMT -7. The time now is 10:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
