01-09-2012, 11:31 AM   #1
The pc connect port has fallen into my k100d
Its been like this for a few years but i always got around uploading photos by using an sd drive. I recently bought a new SD card (SDHC) and i need to update the firmware on my camera to use it. I cant find any of my older sd cards and i need to take photos for a friend. I was curious as to how easy it would be for me to open up my camera a fetch the port and put it back into place? Would i have to take the entire casing off?
I dont have the money to take it somewhere to get it fixed and i've done some minor electrical work before so i was thinking about doing it myself.
Any thoughts? I could use some advice
also im new here and im not sure if this is the right thread for this, if im in the wrong place being pointed in the right direction would be welcomed.
01-09-2012, 01:10 PM   #2
bluestringer's Avatar
I would just get a cheap 1gb SD card, put the firmware on it and load it from there.
01-09-2012, 01:26 PM   #3
wlachan's Avatar
You can just remove the bottom plate and see if you can shake it out. If that didn't work, then the top has to come off partially for the side panel to be removed. This can be dangerous if not careful. I wouldn't recommend solder it back in place because you can kill the circuit easily.
01-09-2012, 11:22 PM   #4
sterretje's Avatar
Fixing the port will more than likely not help you in updating the firmware; if the camera does not support SDHC, it will not be able to write to it and/or read from it. The first one can be circumvented by putting the card in the PC, the second one can not be circumvented.
camera, im, pentax help, photos, port, sd
News Introducing facebook connect! Adam Site Suggestions and Help 13 12-05-2011 12:42 PM
Snapped off USB port on k100d BrianR Pentax DSLR Discussion 7 12-14-2010 09:33 AM
Quantaray lens-how to connect to my Pentax Kx jfegan12 Pentax SLR Lens Discussion 10 11-09-2010 11:59 AM
how to connect my *istD to an astronomical telescope techristian Pentax DSLR Discussion 5 05-23-2010 06:46 AM
Quick question pc port vs miniphone port SuperAkuma Pentax Camera and Field Accessories 5 07-10-2009 02:01 PM
All times are GMT -7. The time now is 05:47 PM. | See also: NikonForums.com, part of our network of photo forums!
