01-12-2012, 09:01 AM   #1
slowpez's Avatar
Using IS with tripod
I know that when using a tripod under normal circumstances you should turn IS off but what if you are using the tripod to photograph birds in flight and are only using it to give you some stability but the head swivels freely?
Thanks for your input.
01-12-2012, 09:03 AM   #2
JinDesu's Avatar
If you are shooting birds in flight, I imagine your shutter speed is going to be well above the range needed for IS. Unless you have a very long lens, then I would still imagine that IS isn't needed - a ball head tripod would remove quite a bit of the small vibrations that IS is designed to counter.
01-12-2012, 10:11 AM   #3
QuoteOriginally posted by JinDesu Quote
But wouldn't having his hands on the head grip as well as on the camera instead of using a shutter delay or remote cause those small vibrations that IS is designed for?
01-12-2012, 10:36 AM   #4
SpecialK's Avatar
If the camera is "moving freely" then effectively it is not on an unmoving tripod. I use it with IS on.
01-12-2012, 10:38 AM   #5
slowpez's Avatar
Thanks for the quick responses. I am trying to keep my shutter speed at 1/1000 s or faster and am using a 55-300 mm lens. Taking birds in flight photos are fairly new to me and seem much more within my grasp now that I have my hands on the K-5.
01-15-2012, 01:11 PM   #6
DaveHolmes's Avatar
I pretty much always forget to turn SR off...
Luckily, the Kx turns of SR when put on 2/10sec timer, so I'm good
Unfortunately... I pretty much always forget to turn the timer off...
camera, pentax help, photography, tripod
Tripod Strap vs Tripod Bag vs Nothing At All reivax Pentax Camera and Field Accessories 16 01-10-2012 07:58 PM
My new tripod KxBlaze Pentax Camera and Field Accessories 29 05-05-2010 05:19 PM
For Sale - Sold: Slik 813 CF II carbon fiber tripod + tripod head (Australia) Edvinas Sold Items 5 08-02-2009 04:56 PM
what's the difference between a cam tripod and umbrella/flash tripod? mike.hiran Flashes, Lighting, and Studio 11 06-23-2009 06:56 PM
Tripod head stuck on my tripod... Buddha Jones Pentax Camera and Field Accessories 11 06-04-2008 07:34 PM
All times are GMT -7. The time now is 12:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
