01-12-2012, 08:13 PM   #1
K5 LCD screen weirdness
I have a K5 and twice now I have put in the SD card and it would indicate there was no card installed.. turning it off would leave a few random appearing gray lines in various places on the LCD screen.. even though the camera was turned off. The reolution in both cases was to remove the battery and reinstall the battery.. a simple fix, but somewhat worrysome that something could be going wrong. Has anyone else had a similar experience??
Thanks in advance for any info.. BOB
01-12-2012, 08:37 PM   #2
Moving this to the troubleshooting section...
It sounds like your screen might have been damaged- this can happen if something presses against it very hard.
01-13-2012, 04:20 PM   #3
Hi Adam... The camera works fine and the LCD looks great.. it's just that twice this has happened.. when I re-inserted the SD card it gave indication that there was no card loaded.. then when I took the card out there was a few gray lines on the LCD screen, EVEN when I turn off the camera!! .. this would repeat UNTIL I removed the battery from the camera.. then just re-instal the battery and all is working back perfect.. same card etc.. LCD then looks perfect again.
Because this has happened twice over the past 3 or 4 months it concerns me that something might be going wrong.. just wondering if anyone else was having a similar rare issue.
01-13-2012, 04:46 PM   #4
bobmaxja's Avatar
Have you try a different card? That will be the first thing to do
01-15-2012, 04:46 AM   #5
QuoteOriginally posted by Pelham Quote
Are you removing the card without turning off the camera?
01-15-2012, 04:10 PM   #6
A similar thing happened to me only once several weeks ago - some stray elements in the top K-5 LCD remained active even after powering off. I can't remember exactly what triggered this but over time (and after a few cycles of recharging the battery from new) I have never seen this happen again.
01-16-2012, 06:24 PM   #7
K5 screen
I recently purchased a new K5 and new card.. After I put the card in the screen would not come on. After I turned the camera off some lines stayed on. Took the battery out, re installed and all was fine. Went through this sequence several times, same thing happened. Put a different card in and
all seems fine. Put the ""offending"" card in my KR and seems okay there.
Yes the power was off when I put the new card into the camera. A K5 quirk or something with the card ??
Regards
John A.
card, k5, k5 lcd screen, lcd, pentax help
Does Kr use same LCD screen as K5 and K7? texoma Pentax DSLR Discussion 7 01-24-2011 12:15 AM
Focusing screen weirdness aarrgghhh! koguma Troubleshooting and Beginner Help 22 09-12-2010 03:14 PM
LCD Screen Protectors: Yes or No? mnseawa Pentax DSLR Discussion 22 06-11-2010 11:26 AM
A Better LCD Screen for the k-x? imno007 Troubleshooting and Beginner Help 2 05-31-2010 08:32 AM
How to keep LCD screen clean? NecroticSoldier Troubleshooting and Beginner Help 7 03-19-2010 11:16 AM
All times are GMT -7. The time now is 05:49 PM. | See also: NikonForums.com, part of our network of photo forums!
