01-13-2012, 04:25 AM   #1
is it broken?
I accidentally removed batteries when camera was on and now it won't turn on. Is it broken? (actually, i managed to turn it on 2 times, but after few shots camera stopped responding).
01-13-2012, 04:53 AM   #2
Stuart Windram's Avatar
It could be that the software is corrupted. Try turning the camera on with the Menu button pressed, it should then show you the software version. If it doesn't do that, then I guess you'll have to send it in to Pentax.
I know this sounds obvious, but are the batteries in the camera correctly? It might also be that there is a bad contact between the battery/ies and the camera. Are they fully charged?
Hope you come right!
01-13-2012, 05:02 AM   #3
nothing happends when i keep menu button pressed.
I bought my camera in Poland and I'm in UK right now. Do i have to send my camera to shop where i bought it, to polish distributor of pentax, or can i send it somewhere in uk? I still got valid warranty.
01-13-2012, 05:18 AM   #4
Can't really help you on that... I'm in South Africa - manufacturer's customer service is generally not the greatest in this part of the world.
My suggestion would be to find a local camera shop that deals with Pentax and ask them there.
01-13-2012, 10:30 AM   #5
Marc Sabatella's Avatar
I've removed batteries with the camera on hundreds of times. That shouldn't in itself have caused any problems.
01-13-2012, 11:05 AM   #6
sterretje's Avatar
Which camera? Which batteries (make / type)? I think it's coincidence and your batteries might have reached end-of-life. If it's a camera that uses AA, you can try alkalines (cheap) to check if it's the camera or the batteries; the camera should at least be able to start up and take a few shots.
01-13-2012, 11:15 AM   #7
If the cam was writing to SD-Card while removing the batteries data might be corrupted. Remove the Card and switch the cam on with new/loaded batteries.
-Linus-
01-13-2012, 11:20 AM   #8
Unless you removed the batteries while the firmware was updating, it shouldn't be a problem. Check the battery connections!
01-13-2012, 11:56 AM   #9
It's pentax k-x. Batteries are fully charged (eneloops). How do i check battery connections?
01-13-2012, 12:22 PM   #10
Look for corrosion on the battery connections.Think sd card is most likely problem.What battery type did you have the camera set for?
Jake
01-13-2012, 01:45 PM   #11
"What battery type did you have the camera set for?"
what do you mean?
sd card is taken out. I don't see any corrosion.
01-13-2012, 10:17 PM   #12
Check page 253 of your manual.
Jake
01-14-2012, 04:59 AM   #13
auto-detect.
01-16-2012, 05:29 PM   #14
DaveHolmes's Avatar
Were you updating firmware at the point that you removed batteries?
There's deffinately no firmware listed on screen if you hold down 'menu' as you switch on?
In UK right? You need to get in contact with a 'Pentax Pro Centre'... My nearest one is the 'Bradford Camera Exchange'...The most well known one I can think of is 'SRS-Microsystems' both will more than likely refer you to the UK Pentax repair centre as you purchased in Poland...
Here's details of the UK Pentax Repair Centre:
Johnsons Photopia Ltd
Hempstalls Lane
Newcastle under Lyme
Staffordshire
ST5 0SW
Telephone: 01782 753350
E-mail: pentaxservice@jpss.co.uk
All this and more info is available at the UK Pentax website...
Hope you get it sorted mate...
01-20-2012, 05:21 AM   #15
thanks.
camera, pentax help
Broken ME, want to take apart Capslock118 Pentax Film SLR Discussion 12 11-12-2010 05:19 AM
Lens is broken: broken mount nemo9439 Pentax SLR Lens Discussion 4 08-27-2010 09:52 AM
IS broken? sealisthenewbeaver Pentax DSLR Discussion 16 08-17-2010 07:00 AM
Broken dreams, broken camera brkl Post Your Photos! 3 03-10-2009 05:08 PM
All times are GMT -7. The time now is 05:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
