First of all, I'd like to say thanks for the responses, you guys are great.
Originally posted by kaiserz What do you mean by good indoor shots? if you have some sample that'll be awesome so we can "critique" you and show some pointers on how to get that "shot" that you want.
And like Mr. rico & jindesu said, bumping up the ISO to achieve the "right" shutter speed to get a stable shot & properly exposed shot is crucial, I believe it's gonna be 1/Focal length = shutter speed.
White balance and other stuff can be fixed in PP.
I went to the wax museum in NYC recently and I had a lot of trouble trying to get a good shot because the lighting situation kept changing. I ended up just overexposing with flash since it was the most consistent photo outcome.
I still have a lot of learning to do...
Originally posted by K57XR If you’re set on using the kit lens I suggest investing on an external flash like the Metz 50 or event the older Metz 48 and use bounce flash for more balanced, natural looking ambient light. Avoid direct flash as much as possible since this usually results in harsh lighting and closed or red-eyed live subjects. Built-in flash can be useful but then again it is a direct flash. The only time I use PU flash directly is for “emergency” where a shot taken is better than no shots taken. Although I haven’t tried the equipment mentioned above or any of the pop-up diffusers widely available, this may be a good option as well.
In case you’re in a place where flash or tripods are not allowed, you can always experiment and put your camera in P-Mode “Museum”, take a shot then look and see what settings the camera used for a particular scene (ISO, Shutter Speed, and Aperture). Then go to Manual mode and use those settings as a baseline then adjust them, take a shot for each adjustment and see how it affects the picture. Adjust them until you get your desired settings. And yes, shoot RAW or RAW+ and PP as needed.
I am not set on using the kit lens. I really want to purchase a lens. I am currently eyeing the DA 35mm f2.4. I am also considering other low light prime lenses. As mentioned earlier, I am very new to photography and still learning. I have read a lot about the kit lens and many have said use it to learn the fundamentals.
I think good practice for me would be to use manual focus and not using the zoom. I find myself shooting a lot at 18mm. I like the wide view; I figure I can crop later if I want to.
