01-19-2012, 06:00 PM   #1
Pentax-DA 35mm F2.4 AL autofocus not working
I just purchased the 35mm F2.4 AL lens 2nd hand and it appears that the autofocus is not functioning as it should. Camera is a k100D. My other lenses all A/F fine, so was just wondering if there was anything I could check before I return it. I can manual focus it (sorta, it's pretty stiff) and if i turn the focus ring while the lens is off the camera, i do see the AF screw drive pin turning. When I hold the shutter, i do hear it twitch, but that's it.
01-19-2012, 06:16 PM   #2
Is the manual focus stiff even when you put the camera in manual focus mode? If so, then AF mechanism is probably broken, though it should be fixable. You might even be able to do it yourself, but if you have the option of returning the lens, do so and get a new one.
01-19-2012, 07:24 PM   #3
VisualDarkness's Avatar
Can you turn the AF screw-drive a couple of times? Once a lens got stuck for my and my brother turned the screw to make it work again.
01-20-2012, 03:40 PM   #4
i can see the screw turn if i turn the focusing ring. it seems to spin freely, but i guess whatever controls it in the lens isnt working. was just hoping for a possible somewhat easier/faster solution than returning it, waiting for a refund, then buying another.
01-20-2012, 03:48 PM   #5
That sounds like normal operation to me. Perhaps the lens wasn't mounted correctly? With the screwdrive AF system, there's nothing in the lens apart from some gears that link everything together.
Does the focus setting on the lens change if you turn the axle on it?
01-20-2012, 03:52 PM   #6
sorry im pretty amateur with your terms
can you explain what you mean by focus setting and turn the axle?
and is it possible to mount it wrong?
01-20-2012, 04:01 PM   #7
if you mean does the rear element move forward and back when i turn the focus ring, then yes.
when i put the lens on the body, if the focus is all the way out, and i point it at something far away, the focus ring will come in about half way then it stops. if i half press the shutter for autofocus, i can hear the motor click, and feel the focus ring twitch, but it does not move in or out. I said the focus ring feels stiff, and what i mean by that is when you turn it, it doesnt feel as fluid as my other lenses. It moves, but not as fluidly/smoothly as say the kit lens. I had read that manual focusing with this lens was difficult, didnt know if that was the reason or if it's something else.
autofocus, camera, f2.4, focus, lens, pentax help, pentax-da 35mm f2.4
K-5 + 18-55mm Wr - Autofocus not working?? hknymz Pentax K-5 11 02-29-2012 04:50 AM
Grrr...autofocus on k-x not working rachcobb Troubleshooting and Beginner Help 9 01-10-2012 09:29 AM
For Sale - Sold: Pentax smc FA 35mm f2 Autofocus AF Fleafly Sold Items 2 12-24-2011 06:11 PM
Do 35mm SLR lenses autofocus on Pentax DSLRs (K-x) ? photoleet Pentax SLR Lens Discussion 3 08-08-2011 04:41 PM
35mm Autofocus:Affordable options? Jetsam1 Pentax SLR Lens Discussion 4 03-16-2011 07:56 AM
All times are GMT -7. The time now is 07:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
