01-25-2012, 11:43 AM   #1
Lens problem
I have an 8 yr old *ist DS with the original SMC DA 18-55mm lens. The lens stopped auto focusing this morning. It tries, but will not "lock in". I also have another lens that "locks" fine. Is it the lens motor on my 18-55 that is shot or what??
01-25-2012, 12:30 PM   #2
Lowell Goudge's Avatar
there is no motor in the lens.
the *istD uses exclusively screw drive, check that the screw drive is engaged into the body. you can do this by applying slight pressure on the focusing ring, and at some point it will try to turn the focus motor, if the ring turns freely the coupling is not engaged,
i have had a couple of lenses that were a little inconsistent in engaging the focusing drive, but normally this is when new not old
01-25-2012, 01:02 PM   #3
Lens problem
Thanks Lowell,
I turned the focusing ring from side to sie. At one end I heard a slight click and the auto focus now works. Appearently it wasn't engaged?
Bill
01-25-2012, 01:06 PM   #4
Ash
Community Manager
Ash's Avatar
Likely the issue. It might have been the slightest of malalignment physically between the camera's screwdriver mechanism and the lens attachment.
01-25-2012, 01:53 PM   #5
QuoteOriginally posted by mrbill6771 Quote
Thanks Lowell,
Bill
glad to help.
this issue confused the hell out of me when I was switching between my PZ-1 and *istD. I think the cameras were leaving the screw drive at different angles.
01-25-2012, 01:56 PM   #6
Sometimes you have to wiggle the focusing ring to get the shafts to align. I guess I've been doing it sub-counsciously, but now that I think about it, the AF won't work if you don't do it.
01-25-2012, 02:00 PM   #7
Lens problem
Thanks, everyone!! You guys have been a great help. One more little nitty to add to the bag of tricks. And this one wasn't expensive!!!
lens, pentax help
lens problem Lynne Visitors' Center 3 11-09-2011 05:38 PM
odd front focus problem with kit lens and Tamron 18 - 250mm lens jlaubza Pentax DSLR Discussion 12 10-30-2011 09:42 AM
Help with Lens Problem AutoEccentric Pentax SLR Lens Discussion 23 08-14-2010 10:24 PM
Problem with automatic lens tfischer Troubleshooting and Beginner Help 10 03-25-2010 05:18 PM
Problem with K100D and M lens basso4735 Pentax DSLR Discussion 5 01-29-2010 01:05 PM
All times are GMT -7. The time now is 09:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
