02-02-2012, 12:21 PM   #31
Once you understand it the current way of things seems fine to me. The focal length tells you the magnification. Crop factor or equivalent to 35mm ratings like point and shoots have, give a perceived magnification or a way of comparing perceived magnification between cameras with different sensors. Once you have used a few lenses on your camera to have a point of reference, you can tell from focal length how a lens will show on your camera. Should you want to compare another camera (like if you were looking at getting a camera with a different sensor size than the one you are using), crop factor will give you some means to compare the perceived magnification (at what focal length will the car fill the frame so to speak, going off the telescope analogy from above).
camera, da, fov, length, lens, lenses, pentax help, photography
Nature After all these years photolady95 Post Your Photos! 21 04-19-2011 09:34 AM
Are you better off then you were 2 years ago? mikemike General Talk 39 10-29-2010 02:33 PM
40 Years since Mr. Hendrix fractal General Talk 41 09-22-2010 11:06 PM
10 years of Pentax calazans Welcomes and Introductions 2 08-19-2010 07:32 AM
42 years Circle of Confusion Welcomes and Introductions 4 04-22-2010 09:45 AM
All times are GMT -7. The time now is 10:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
