01-30-2012, 09:50 PM   #1
Bulb issues with K-x
Hi all!
Tonight I went outside to take some longer exposures with my K-x, and was happy with the results. However when I put the camera to bulb and kept the shutter open for a minute or so, when I let go of the Shutter, the camera’s buttons did not function the outer screen was not lit (the inner was) and I had to turn it off and then on to get it to work.
I thought perhaps it was the cold, but tried it again indoors after it warmed up, and it did the same thing.
The backlit display was off, only the inner display worked. The pop flash did pop up, but no other buttons or functions seemed to work, and going to other camera modes did not help either (I was in manual).
However unlike outside where I lost patience and shut the power, inside the house I waited and about a minute (or more) then the display came back on & showed the picture, and everything worked.
I am under warrantee and I’m curious to see if this is a design flaw or not, or whether I need to update the system. I did update about a half a year ago.
If anyone who has a K-x could please try this experiment I’d appreciate it.
Suggestions?
Thanks
Jake
01-30-2012, 10:37 PM   #2
K57XR's Avatar
QuoteOriginally posted by FrumPilot Quote
Hi all!
Suggestions?
Thanks
Jake
It sounds like Dark Frame Subtraction. The K-x will perform DFS at exposures longer than 30 seconds and will not let you do anything during the process, this is normal.
Here's a short thread: https://www.pentaxforums.com/forums/pentax-beginners-corner-q/74669-dark-frame-subtraction.html
and this one: Dark-frame subtraction - Wikipedia, the free encyclopedia
Hope this helps!
01-30-2012, 10:46 PM   #3
krp
krp's Avatar
That is the dark frame subtraction. Its purpose is to reduce noise and it makes you wait twice as long to use your camera again.
01-31-2012, 06:43 AM   #4
Wow I never knew about that!
It seems that there's no way to turn that off. Thanks so much for your response.
Jake
bulb, buttons, camera, display, k-x, minute, pentax help, pop, shutter
Bulb mode Matheias Pentax K-r 7 11-09-2013 07:54 AM
Bulb mode MrK5 Pentax K-5 11 01-25-2012 05:52 AM
Has anyone tried the Bulb Mode on K-5 Pentax Lover Pentax DSLR Discussion 22 11-24-2010 07:27 PM
Bulb blower Russell-Evans Pentax Camera and Field Accessories 5 09-12-2010 08:38 AM
Bulb jolee1990 Troubleshooting and Beginner Help 5 04-01-2010 05:01 AM
All times are GMT -7. The time now is 11:39 AM. | See also: NikonForums.com, part of our network of photo forums!
